| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
how do i remove the trunk garnish?
how do i remove the trunk garnish? i want to remove it so i can wrap it in vinyl. i would like to know how to remove the subaru badge as well.
thanks |
#2 | |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
But in all honesty I thought the emblems are all on via tape, so heat them up, and the interior is held on by pins inside.... Touch that Subaru emblem and your still going to hell though.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
#3 | |
i have the interior clips out and the bolts r exposed now... i took off 5 nuts with a 8mm socket now what? |
im already goin to hell lol
it didnt even loosen up the garnish
should i snap a pic?
thanks for the help |
OEDC
Are you talking the inside crap or the piece that fits into the slot right under the top of the trunk on the outside....
Shit some how I got my trunk stuck closed.
My BRZ FI Build
this on the exterior
#9 | |
i need to remove that so i can vinly wrap it |
#10 |
OEDC
Search "trunk stuck" while looking for my solution I think I saw a DIY on how to remove that and the 3rd brake light.
My BRZ FI Build
#11 |
got it.... remove interior pannel about 7 clips.
then use an 8mm socket to remove 5 nuts. then pinch plastic clip on the left and pop it off. you might have to shake it lightly to get it loose. now its off. to remove the badge heat it with a hair dryer and use a credit card to pop it off done!!!!!! i will post pics when i vinyl wrap it and re-install it |
#12 | |
RedBunny w/ Wing
can you post picture of how you remove the trunk stuck???
#13 |
#14 |
RedBunny w/ Wing
NVM. I figure out..i was asking how you remove the trunk garnish, because I want to plastidip that piece too...
| DIY REQUEST: How to remove the fender garnish/vents? | shishand | DIY (Do-It-Yourself) Guides | 37 | 09-11-2015 07:21 PM |
| Carbon Trunk Emblem Cover Garnish | davidchoi | BRZ First-Gen (2012+) — General Topics | 8 | 01-06-2015 03:51 AM |
| Carbon Fiber Trunk Garnish & Fender Inserts | GuerillaRacing | Cosmetic Modification (Interior/Exterior/Lighting) | 50 | 06-26-2013 01:03 PM |
| Trunk Garnish | Wesley | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 06-05-2013 12:49 PM |
| Scion FRS Trunk Garnish wishlist item request | midnightfrolic | Exterior Parts (Aero, Lighting, Etc.) | 0 | 11-30-2012 02:59 AM |
