Drives: GT86
will help minimize heat soking. whatever heat generate from engine bay?
im willing to heat tape warping the whole IC pipes intake pipes with DEI heat tapes dose those work well keeping the pipes cooler?? anyhelp ill me much appricaite it thanks.. |
in orbe terrum non visi
Drives: violent
Throttle body has coolant running through it so unless you're talking about a section close to the exhaust or the turbo I dont think there is a benefit.
Not trying to be a ****
Drives: BRZ - 6MT - GBS
Here's some reading for you
I know there's more out there, but that's all I found in the first 2 mins of searching. Honestly don't know how much it would help, but surely it would if you were sitting in heavy traffic. Black absorbs and radiates heat as well, so its going to take the heat from being behind the radiator and on top of the header and radiate it into your intake path... right? Questions like this make me wish I was an engineer or something.
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
Drives: Scion fr-s
I would put gold reflect tape all over the I/C piping.. heat wrap the headers, turbo blanket and i would vent the hood.
I 2nd the vented hood idea as well. Especially because some are experiencing hood lift at higher speeds.
Drives: Attitude
Yes, it helps. Any older forum will have at least one thread where someone throws up some FLIR-type pictures of various tape arrangements in the engine bay, along with a k-type thermocouple in the engine bay to show differences in ambient bay temps.
Drives: car
Well here's a question.
We know the heat tape can overall engine bay temperatures down. Now, the heat has to go somewhere right? Does the heat tape end up trapping heat inside the pipes, making the charge air hotter? |
#8 | |
Edit: what you're talking about is why someone else mentioned a vented hood edit 2: not to be confused with heat wrap/exhaust wrap which keeps heat inside of your exhaust and out of the engine bay.
#9 | |
Drives: AE86, 2x GT86, TE27
The coolant flows into the throttle body to act as a heater for the throttle body mechanism, in especially cold climates. If you don't experience these cold climates, removing the coolant flow from your throttle bodys is one of the first mods you should be doing. |
#10 | |
Drives: violent
#11 |
#12 |
even if the coolant heats up the intake air, lower input temperatures will ultimately lower temperatures past the TB right?
#13 |
Drives: 2013 Firestorm FR-S
The coolant hoses to the TB are to keep the TB from icing over (like previously stated). It has almost no effect on the temperature of the air moving through the TB compared to the amount of heat the black plastic of the intake path/manifold absorbs from the engine/bay.
Heat reflective taping the intake path might help keep the air temp from rising even more, but in reality, you have to look at how long the air spends in the intake path (less than a second, maybe a full second at idle). Reflective taping has a greater effect on keeping heat out of closed systems, like brake lines and coolant lines, because they can absorb heat from their surroundings and trap it in the system. Sure, the coolant system has a way to manage it's own heat, but the more you keep out of the fluid, the less work your radiator/thermostat have to do. The brake system, on the other hand, has almost no method to reduce fluid temps, and is very susceptible to heat transfer from the rotors through the calipers. |
#14 |
Drives: violent
This is getting out of hand. Let me start over.
What im saying is on front mount turbos where the maf pipe crosses over the hotside of the turbo there is a benefit. BUT just wrapping ic piping to shield it from abient engine bay temps when you have coolant running through your TB isnt going to make a big enough differance imo. Im going to do the back of my fan motor on my fbm kit where its near the downpipe and my intake pipe where it crosses over the radiator hose and near the hotside to prevent heatsoak. BTW dei silver seems to handle more heat than the gold. |
| Guns and Hoses Benefit autocross August 4th | Nomadtrash | Tracking / Autocross / HPDE / Drifting | 5 | 08-08-2013 05:41 PM |
| Benefit of dark wax? | Barbarian | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 07-18-2013 06:31 PM |
| Eibach Benefit Track Day at Chuckwalla May 3rd | Jackson | Tracking / Autocross / HPDE / Drifting | 30 | 04-29-2013 07:48 PM |
| 2014 WRX benefit the 86? | SanDiegoFRS | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 02-18-2013 10:50 PM |
| Refuel NY! Benefit shirt for those affected by Superstorm Sandy | blipshift | Miscellaneous | 2 | 11-13-2012 11:33 PM |
