Old 09-05-2013, 10:01 AM   #1
jonbonazza
CEL code P0172
Okay, so yesterday I started my car up after work and I got a cel. I pulled the codes this morning and I am getting code P0172 and another code. I forgot to write the other code down and I am at work right now, so I will get the other code this evening to help diagnose the issue(s) (hopefully it's related).
The filter is almost brand new, with less than 1500 miles on it. It's part of my AEM Intake setup. Only other engine mode I have is a header-back exhaust (Invidia catted front pipe and FT86SF V2 cat-back). I have had the catback part of the exhaust on there for about 2 months now, while the front pipe has only been on for about a month. Unless an O2 sensor has gone bad, I can't see the exhaust causing an issue.
Any ideas?
jonbonazza is offline   Reply With Quote
Old 09-05-2013, 10:19 AM   #2
sklimo
@whitefrs is this the camshaft position sensor code?? I can't remember
Old 09-05-2013, 10:34 AM   #3
jonbonazza
According to Torque it's the "System is too rich" code.
Old 09-05-2013, 11:43 AM   #4
lexusb3
Drives: FRS
camshaft position codes are P03 numbers
lexusb3 is offline   Reply With Quote
Old 09-05-2013, 11:44 AM   #5
lexusb3
Drives: FRS
your right you are too rich..do you have a tune? or you just bolted everything on?
Old 09-05-2013, 11:47 AM   #6
jonbonazza
Bolted everything on, but if anything, the intake should result in >= airflow, and I can't imagine the exhaust would make the car run rich enough to warrant a CEL. Plus, it's been over a month since the last bit of exhaust work. If that was the culprit, wouldn't I have seen a CEL sooner? Regardless, a tune is in the works, so yea... Should I just wait for the tune and not worry about it?
Old 09-05-2013, 11:54 AM   #7
lexusb3
Drives: FRS
i would go through a process of finding out the problem first put the stock intake on see if it comes back on then switch it back, disconnect the battery restart the system, make sure everything else is on right etc etc, but ya its odd that its running rich i would understand lean more than rich? if not when they tune im sure when they plug it in they will see whats going on? just my opinion
Old 09-05-2013, 11:56 AM   #8
jonbonazza
In teh end, the stock intake is probably better anyway, so might as well throw it on and see what happens. I'll do that this evening after work. thanks. =)
EDIT: It will probably be a few months before a tune is in order. At least it's running rich and not lean, so it's not really hurting anything.
Old 09-05-2013, 12:04 PM   #9
lexusb3
Drives: FRS
hurting your fuel economy lol
Old 09-05-2013, 12:19 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
While >= airflow is possible, if the MAF sensor scaling is not correct it doesn't know how to properly interpret that airflow and may be reading more airflow then is actually entering the engine making it run rich. This is why putting an aftermarket intake on a MAF tuned car is a gamble.
Old 09-05-2013, 06:52 PM   #11
jonbonazza
I see... Well, i pulled the second code. Its P117B. Cant find anything on this code. Any ideas?
Sent from my Nexus 4 using Tapatalk 4
Old 09-05-2013, 07:54 PM   #12
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Rich can overheat your cat. Exhaust tuning can definitely affect O2 content of exhaust gas due to pulse effects. If your header is pulling exhaust out less efficiently than the ECU expects you can run rich.
Suberman is offline   Reply With Quote
Old 09-05-2013, 08:05 PM   #13
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
did you go back to stock airbox? just go back to stock airbox and try out like a TRD air filter drop in, best advice I can give ya
or get tuned for your setup!
448hpsti is offline   Reply With Quote
Old 09-05-2013, 10:51 PM   #14
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
P117B (Fuel System Abnormal (Di))
Hope this helps. From what I have seen, that code is coming up for people with an aftermarket intake.
|-Goku-| is offline   Reply With Quote
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
Check engine light came on (p0172) milkesfrs Issues | Warranty | Recalls / TSB 5 08-17-2019 04:33 AM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 05:23 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 12:22 PM
FR-S Chassis Code mediumbrown Scion FR-S / Toyota 86 GT86 General Forum 2 08-01-2012 11:04 AM
