Drives: Whiteout FR-S
Auto Trans Fluid Drain & Refill
Just finished draining and refilling my diff and went to move on to the trans. I've located the drain plug, overfill plug and refill hole but don't seem to have the right socket size for the refill plug. Any ideas as to what size it is? Largest I have is a 19mm and I'm just speculating it'll be around 20-21mm. Searching hasn't shown anything and the manual doesn't state it either. I checked out the IS250 forums since that's where the trans is from but no one there has done it on their own.
Sent from my SGH-M919 using Tapatalk 2 |
I've already read through that and it covers the manual trans. The automatic trans is different. There's no bolts on the auto trans that uses the 10mm hex socket.
This post has the PDF of the auto but damned if i can actually find in it what size they are page 140.
--- http://www.ft86club.com/forums/attac...7&d=1339384129 |
#5 | |
| FRS/BRZ Manual Trans Fluid | shellslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 131 | 11-02-2017 11:44 AM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| Change trans fluid thru dipstick | bigsley18 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 07-18-2013 11:16 AM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
