Old 09-09-2013, 01:40 AM   #1
Dezoris
Dezoris's Avatar
Rear Wheel Bearing or Normal
Was doing alignment and spinning rear left wheel and felt resistance. Right rear wheel was ok. Obviously parking brake was off is this normal resistance from diff?
Can someone check theirs?
Old 09-10-2013, 10:21 AM   #2
PITTFRS
Drives: 2013 FR-S Hot Lava
normally there will be some kind of resistance on the drive wheels so i would say this is normal.
Originally Posted by Gaiakai View Post
If you're not driving like your car runs on the blood of virgins, you're doing it wrong.
PITTFRS is offline   Reply With Quote
Old 09-10-2013, 11:37 AM   #3
clintavo
Just checked mine both in gear and in neutral. Felt identical left to right.
Parking brake drag? Caliper drag? I would exercise the P brake; remove the caliper; remove the rotor. Stop each time to see if it makes a difference.
BTW, thanks for your significant contribution to the community.
clintavo is offline   Reply With Quote
Old 09-10-2013, 01:16 PM   #4
Dezoris
Dezoris's Avatar
Thanks appreciate it, will double check that when doing brakes this week again.
Old 09-10-2013, 01:33 PM   #5
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
If it is a wheel bearing you'd hear it growning with a low wa-wa-wa-wa type noise (it's almost impossible to describe a noise through typed words) that would change frequency with speed.
More than likely you were feeling brake drag. Separate the brake pads from the rotor (a screw driver works fine) and give it another spin.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 09-10-2013, 01:58 PM   #6
Dezoris
Dezoris's Avatar
Seriously, spent almost 24 hours in 2 days in a 100 degree shop, losing mind.
Thanks will check all that. Tires are so loud hard to tell if noise is bearing or not. Will check brakes.
Old 09-10-2013, 02:08 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
When wheel bearings go bad, they tend to have a low frequency grinding noise that gets worse if you put more load on that wheel (i.e. turn the car to put load on the wheel).
You won't be able to tell a bad bearing by simply spinning the wheel by hand, you'll usually first hear it while driving.
-alex
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 11:21 AM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 04:58 PM
Thrust Bearing Going Out >(559)< FR-s Issues | Warranty | Recalls / TSB 22 06-19-2013 09:23 PM
bearing identification paraguin Other Vehicles & General Automotive Discussions 7 04-16-2013 11:18 AM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 11:34 PM
