Old 09-11-2013, 08:53 PM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Hawk Performance Ceramic Pads? Anybody try them...?
I'm looking for a set of better than factory brake pads to do a track session with. These look ideal. Has anybody tried them?
http://www.frsport.com/Performance-C...-_p_59094.html
hmong337 is offline   Reply With Quote
Old 09-12-2013, 04:50 AM   #2
Teo
Teo's Avatar
I have on my BRZ, front and rear.
Are good pads, make no-noise and improved performance for light track use.
I run for 30minutes on the track and no fading at all, also, more than 3 consecutive laps on the Nordschleife without any problem or fading.
I also have brake lines and DOT 5.0.
But are not high-performance race pads, I've tried BRZ with Endless pads and was really another planet! - but also another cost!
Teo is offline   Reply With Quote
Old 09-12-2013, 03:34 PM   #3
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i will never run hawk hp's ever again. Made them fade in my STi on mountain runs. I much prefer the stop tech street pads.
bkblitzed is offline   Reply With Quote
Old 09-12-2013, 04:19 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you are looking for a street/track pad then you need to step up past the ceramics and HPS to the HP+ if you want to run Hawks.
Old 09-12-2013, 04:25 PM   #5
infinite012
Drives: 13 DGM BRZ Ltd
I had Hawk Ceramics on my 08 STI. Good bite, no noise, lower dust than stock pads by a long shot. Stopping distance probably was as good or slightly better, but not noticeable.
I'd give them a shot on the BRZ.
infinite012 is offline   Reply With Quote
Old 09-12-2013, 04:35 PM   #6
frslee
Just drive it
Drives: 13' FR-S
Hmm... I like semi-metallic on brakes. It creates a lot of dust than ceramics, but stops better. I personally experienced on my past car. Stock pads were semi-metallic, then I tried Akebono, which is ceramic. A lot of people in the forum recommended akebono, but stock stopped better.
frslee is offline   Reply With Quote
Old 09-14-2013, 11:41 AM   #7
hmong337
Emperor JDM
hmong337's Avatar
Thank you for the replies.
Light track use is what I'm aiming for. Definitely not going to be racing but will be doing a a few hot laps here and there.
Maybe the stock pads will suffice?
Old 09-14-2013, 12:48 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
FTR, Hawk HPS are the suckiest suck pads that ever sucked. WAY worse than OEM on my s2k. HP+, however, have worked well for me at the track, but lords dust and squeal on the street.
For a mostly streetable trackworthy pad, Carbotech XP8or even XP10 (have them on my rx7 at the moment).
Old 09-14-2013, 02:19 PM   #9
hmong337
Emperor JDM
hmong337's Avatar
Yes, everybody that uses Carbotech almost always has something good to say about them. I will look into them further.
Old 09-14-2013, 04:59 PM   #10
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
hawk is ok. its better than stock but not by much .
but if its a 5 foot difference 60-0 and you need to break hard, that 5 feet might save your ass.
get dimpled/slotted rotors when its time to get pads. that will make a bigger difference than just pads... all my cars/trucks have slotted/dimpled rotors and i will never own a car without them. you will need to replace the rotors one day anyway
NYCsubaruBRZ is offline   Reply With Quote
Old 09-14-2013, 07:24 PM   #11
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
change fluid is what I would suggest for sure tho
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 09-23-2013, 12:03 PM   #12
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
For street and track use which is 90% of our customer base, we've done a lot of testing of pads on track and on the street in the past 10+ years. Here is our recommendations based on use and cost...
Hawk Ceramics- Good for soccer moms who don't want noise or dust. Good OEM replacement. Cost is a bit higher than the ST ones though.
Hawk HPS- Good upgrade to stock or as a stock replacement, good enough for a HPDE Level 1. Low dust, low noise.
StopTech Street Performance- Low cost of entry, higher temp rating than the HPS/Ceramics, on par with or higher than HP+. We've been using these for OEM replacements. Good for most DE situations on non-race tires.
HP+ Great Auto-x and DE and street pad, on non-race tires. Can be an issue on cold mornings for DD, I've never had an issue, but others have complained about cold pad issues. Price is good as well.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Now we have an Online Catalog where you can purchase Parts! AZPParts.com
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 09-23-2013, 06:38 PM   #13
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
-Mike Paisan
How's the noise on the StopTechs?
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 09-23-2013, 07:31 PM   #14
ubersoph
Personal experience - they squeal a little bit, dust like hell, but they are consistent.
ubersoph is offline   Reply With Quote
Hawk HP+ front brake pads DChan415 Brakes, Suspension, Chassis 3 08-23-2013 09:20 AM
FS: NIB Hawk HP+ Front Brake Pads djfuller Brakes, Suspension, Chassis 4 02-22-2013 12:59 PM
Hawk Blue 9012 Race Pads sw20kosh Tracking / Autocross / HPDE / Drifting 15 02-14-2013 11:57 PM
Hawk HPS Front Pads Sheldon Brakes, Suspension, Chassis 1 01-04-2013 04:54 PM
Hawk ceramic brake pads yomchi1989 AUSTRALIA 5 09-26-2012 11:39 AM
