Old 09-18-2013, 04:49 AM   #1
juliog
juliog's Avatar
Drives: 86
You're doing it wrong: common driver errors
http://www.motoiq.com/MagazineArticl...ng-Issues.aspx
juliog is offline   Reply With Quote
Old 09-18-2013, 07:36 AM   #2
alan.chalkley
Drives: 4wd zooks
The worst one that i see every day , is driving with one hand inside the steering wheel.
They wonder why they lose control if they slam on the brakes and the car slides.
alan.chalkley is offline   Reply With Quote
Old 09-18-2013, 08:25 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You go to the track every day?
Old 09-18-2013, 09:15 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
It’s because you leapt off the brake pedal like it was your high school girlfriend when you heard the garage door opening.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-18-2013, 10:10 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
he didn't bother reading the article
Old 09-18-2013, 11:37 AM   #6
whaap
whaap's Avatar
I still think the most common error made by drivers is their not knowing how to properly adjust their side view mirrors. So many complain of blind spots when, mirrors properly adjusted, there are none.
whaap is offline   Reply With Quote
Old 09-18-2013, 11:41 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Funny, I know that Sentra and it's driver. While it was heavily loaded there I'm not quite sure it was understeering
Brake release is key. I and others have mentioned release properties in brake pad discussions for that reason
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-18-2013, 12:15 PM   #8
If you unwind the wheel 10% then only add 10% throttle, unwind 20% add 20% throttle, and so on until your full throttle in a straight line.
This is the hardest concept for people to grasp, IMO.
Old 09-18-2013, 12:30 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
people that stab the throttle during slaloms make me go \ O.o /
Old 09-18-2013, 12:56 PM   #10
SkullWorks
Drives: SSM LT MT BRZ
I saw that yesterday, it was a good read but not as in depth as I might have hoped. But all good things to keep in mind.
SkullWorks is offline   Reply With Quote
Old 09-18-2013, 02:32 PM   #11
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I've been working on the last part about braking for a long time. I find it fairly easy to look through the turn in the FRS (slower speeds) but when I'm doing 165 MPH into a 180 degree turn, fighting car control under braking, it's so difficult to look past your turn in! I get it right sometimes and it's magic
Element Tuning is offline   Reply With Quote
Old 09-18-2013, 03:22 PM   #12
Where do I buy a set of these CF nuts?
Old 09-18-2013, 06:40 PM   #13
Captain Snooze
Drives: Red Herring
"Here’s the way it’s supposed to work............. keeping that apex in your peripheral vision."
My problem (and its not just related to track driving) is that 'tho my peripheral vision is fine (that is, my eye sight works at the peripheries) my brain only concentrates on what I'm looking at directly. So if I'm looking through the cars' windows in front of me looking for brake lights up in front I might not be aware of the car directly in front of me slowing down. Another example, I'm looking (not glancing) at my revision mirror and my peripheral vision sees the car in front slowing down but I'm concentrating on my mirror so I'm not aware of the car in front. Just sitting at my monitor here, if I wiggle fingers at the sides of my head I have to concentrate on seeing my fingers and even tho the text is right in front of me I am no longer concentrating on the text but my moving fingers.
I don't find this to be much of a problem because I have taught my self to be constantly moving my field of view, that is don't stare at the one object for long but it makes the looking ahead at track a little tricky because if I'm looking a head I lose awareness of the track near by.
Advice would be welcome.
(Wow, long story)
Old 09-18-2013, 06:51 PM   #14
DarkSunrise
DarkSunrise's Avatar
I started a thread on this earlier, but this is the one I'm guilty of sometimes:
Most people’s minds tell them to hold the inside just a hair longer to the point where they start releasing the wheel and adding throttle and by the time they’re pointed straight they're a car width away from the edge. That way feels safe, and it is safer but it’s not as fast. ... If you end up in the middle of the track then start unwinding your steering a little earlier.
2022 BRZ Build
2013 FR-S Build
Common sense!! tintumz22 Off-Topic Lounge [WARNING: NO POLITICS] 31 05-22-2016 08:24 AM
BRZ/frs vs common sense. Adeets FR-S / BRZ vs.... 0 03-25-2013 05:12 PM
Argento FRS not common? Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 34 01-24-2013 05:50 AM
Errors: Tapatalk & FT86 ironchef Site Announcements / Questions / Issues 1 11-29-2012 09:40 AM
Common problem? BRZ NA Scion FR-S / Toyota 86 GT86 General Forum 35 10-28-2012 06:25 PM
