Drives: Scion FR-S
Valenti rear fog alternate wiring
I ordered the valenti smoked rear fog light from modbargains.com to match the valenti tails. They were extremely helpful with the order, and shipped on the same day that my order was processed. After receiving the order I contacted modbargains for help regarding an alternate wiring setup to have the V and the LED triangle function seperately. They were nice enough to send back step by step instructions to get it to function exactly as I wanted. Overall it was a great experience and Im very thankful for their help! I think that having the V function without the LED triangle gives a much cleaner look!
The setup below functions as follows: V on with headlights LED triangle lights up when brake is depressed with no flashing Reverse- no changes headlights on: ![]() brake depressed: ![]() night: ![]() Instructions: 1. Remove 10 phillips screws from the back of the light. 2. you will see a dark blue wire connecting the V to the LED triangle 3 Remove the blue wire from where its connected to the red wire - I just cut the wire and left some of the blue hanging there 4. Locate the orange/black wire that goes to a single red wire. This is connected to the LED triangle where "Rev" is written 5. Disconnect the orange/black connecter 6. Leave the orange/black wire alone, it will still be connected to the LED triangle but will not function. 7 Remove connector from the single red wire 8. Connect the single red wire to the blue wire with connector/soldering iron 9. Put the back cover back on. 10. Follow the installation instructions on modbargains website with the important exception that the LIGHT BLUE wire will now connect to the brake (red wire going to tails) and the single red wire will connect to the running lights (blue wire going to tails) Wiring: The blue wire has been cut from where it originally connected to the red, linking it to the LED triangle. It has been soldered to another blue wire (that modbargains was nice enough to provide) and then connected to what I was referring to above as the "single red wire". This will connect to the blue wire going to the tails. The red wire seen in the picture controls the LED triangle, and becomes a light blue wire (not in pic), this will connect to your brake (red wire going to tails) The orange and black wire has been disconnected and I left it just hangin there ![]() Hooking into tail lights (red goes to blue, blue goes to red)
thanks for the info, i have the valenti tails and strip too. had them hooked up to be fully on w/ the lights, now it seems they only work when i'm in reverse... so this will help me when i try and figure out what happened with the wiring lol. thanks
Drives: Series 10 FR-S
Pics would be nice. Great work on doing this wiring. I was looking to do this too but couldn't figure out the exact steps.
JDM JUNKY
Drives: NSX
get some pics / vids up yo !
Drives: Scion FR-S
Sorry I thought the pictures were working! I'll upload them the correct way when I get home tonight
I used a connector for the Single Red (previously Orange/Black) to cut Blue wire, the one between the light bar and triangle.
I don't know much about wiring, but I did not see the need to solder the cut Blue wire to the ModBargains provided Blue wire and then solder that to the Single Red wire, so I left it alone, and it seems to be working fine - again though, I am not an electrician by any stretch of the imagination! For those of you that have Green and Green/Yellow wires instead of the Blue, Red, Yellow, and Black wires for your taillights, here's how I did mine, with Blue to Green and Red to Red: ![]() Turned out great! ![]() Note: while this works, it seems like you give up the F1 function for the chance to use the light bar and the triangle separately, one as a brake and the other as a parking light. @Phaedrus29 has indicated in this post that it might still be able work though!
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I like the looks of it, and thanks for the effort you put in making a DIY. However over here you would probably have the car impounded if you drive with the lights wired like this. Its a shame, as i really looks nice :-(
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
Great write up! Thanks for posting that up!
Drives: Toyota 86
@ModBargains.com, For Curiosity sake:
How about a setup with functions as follows: 1. -v- ON with Park Lights ON but not the LED triangle 2. LED triangle lights up only when brake is depressed WITH flashing 3. Usual Reverse Lights. |
#10 | |
Drives: BRZ Limited WRB MT
#11 |
Drives: Firestorm FR-S
#12 | |
Drives: Toyota 86
- LED triangle lights up ONLY when brake is depressed WITH flashing. it's WITH the Flashing or F1 Light Function upon breaking. what is stated above is NO Flashing... ![]() ![]()
#13 | |
"LED triangle lights up ONLY when brake is depressed WITH flashing. it's WITH the Flashing or F1 Light Function upon breaking." That is what I want
#14 |
Drives: Toyota 86
Hahaha... I thought you stating the answer I was looking for is stated above, the first post. Silly Me...
| Tags |
| rear fog, valenti |
| Wiring BRZ rear fog light to only come on with front fogs | Scenic Driver | DIY (Do-It-Yourself) Guides | 4 | 09-12-2015 10:36 AM |
| Valenti Japen LED Reverse Tailight USDM Wiring | Furtive | DIY (Do-It-Yourself) Guides | 12 | 08-21-2015 10:31 AM |
| Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 12:57 PM |
| Valenti Tail Lamps and Tommy Kaira Rear Spoiler | harajukukei | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-04-2013 08:01 PM |
| Alternate TRD Rear Bumper Possibilities | Breeze Loo | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-06-2013 02:06 PM |
