Kelford Cams FA20 High Performance Valve Springs
Just got a set of these in stock and likely will have a set on our silver car soon....
Kelford Cams FA20 High performance valve spring set for the Scion FR-S and Subaru BRZ. Manufactured for us by PAC Racing springs using the finest Kobe wire and PAC's world renowned manufacturing processes. These springs drop in on the stock retainer to raise the seated pressure from 50lb to 68lb in order to give added protection and proper valve-train control in forced induction applications or higher rpm naturally aspirated applications. 68lb seat pressure at 32.6mm installed height using OEM retainer and base. 166lb open pressure at 11.5mm lift, maximum lift is 13.00mm |
Drives: K24 Swapped FRS
"Dear Heavenly... uh... Spirit. Thank you for providing us with the direct-port nitrous... uh... injection, four-core intercoolers, an' ball-bearing turbos, and... um... titanium valve springs. Thank you."
#3 | |
Drives: Attitude
Drives: 2003 Subaru Outback
If they aren't here yet....at least tell us they will be soon
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Pricing?
Sent from my Nexus 4 using Tapatalk 4
Nolan
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
For use with oe cams?
Drives: Challenger R/T, CRX SI,
Yes these will work with OEM cams.
Pretty much designed that way to increase rev range for those who are NA, and provide a bit more security for those boosted as the rev out their motor. |
#10 |
In Test:Oil Fed SC
I'm very curious, who has installed these? Pm me if you can offer me tester/Ginea pig/early adopter deals
#11 |
The Mechanic
Drives: Civic Turbo,FR-S
just need cams that actually make power past 7500 because stock ones dont lol
#12 |
Drives: 2013 Asphalt FR-S
i think some cam manufacturers have shied away from doing cams because the stock springs are too weak... that's the rumor i have heard anyway.
~Namaste~ |
#13 |
Add lightness!
Drives: 17' WRX
Really? Doesn't seem to make alot of sense since replacing the cams on this car is quite the chore. I doubt anyone motivated to change the cams would have a problem changing springs/retainers at the same time since. Springs have been available from Ferrea for a while too.
Last edited by industrial; 09-25-2013 at 09:21 AM. Reason: grammer...not enough coffee |
#14 |
Drives: GT86
Cams on a 100hp/litre engine aren't likely to be particularly mild, to say the least!
| Tags |
| fucking springs |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 10:23 PM |
| HKS Premium Day 2013: FA20 stroker kit and cams | cyde01 | Engine, Exhaust, Transmission | 33 | 06-18-2014 04:03 AM |
| FA20 Fuel lean at high boost fix | cf6mech | Forced Induction | 15 | 05-20-2013 04:33 PM |
| $28K High-Performance Two-Door Comparison | Asterisked Accolade | Other Vehicles & General Automotive Discussions | 3 | 06-07-2012 01:20 PM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 10:42 PM |
