Old 09-30-2013, 07:35 PM   #1
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
click, clank click sounds when cooling down and more? leaking oil?
Hey,
I am sure this is me being paranoid but I wanted to verify with other toyobaru drivers that their car is doing the same thing.
I know that when you turn off your car its going to make some clicking, clanking noises while the oil settles and the engine begins to cool off. But, i swear to god that I have an entire orchestra of loud sounds! I can hear it from a good distance of my car.
In fact, yesterday I heard the sound of a clink...........clink...........clink ( a good 3-4 seconds in between) while in idle. I then turned it off and other types of clink, clank sounds started to make that orchestra I mentioned.
I should mention I have a Unichip tune.
I am thinking that maybe that first clink that occurs while the car is running may be that oil drip that some drivers get. Apparently, oil leaks onto the OP and burns causing an odor... maybe I am hearing that drip while it is at idle? I am going to check my oil to see if I have lost any.. that should be an indicator that something is wrong.
thanks
Boofneenee is offline   Reply With Quote
Old 09-30-2013, 07:50 PM   #2
kodyo
Drives: Scion FR-S
I think it is pretty normal. My car does this as well and my old car (2000 honda accord) also did this.
kodyo is offline   Reply With Quote
Old 09-30-2013, 08:09 PM   #3
dummyy
Drives: Asphalt FRS
ditto. definitely noticeable in the garage. pretty sure its normal
dummyy is offline   Reply With Quote
Old 09-30-2013, 08:17 PM   #4
White64Goat
It's most likely the cover over the cat cooling off. It's pretty common on a whole lotta cars. And the exhaust too.
Old 09-30-2013, 08:19 PM   #5
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
If anything, you would be the only one who can find those sounds and/if oil leaks.
Old 09-30-2013, 08:20 PM   #6
leon78
leon78's Avatar
Drives: 13 Whiteout
Cars totaled....Trade in and buy a civic right away.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 09-30-2013, 08:42 PM   #7
Burrcold
Drives: Subaru BRZ Limited
Heat shields? ...Heat shields.
Old 09-30-2013, 08:49 PM   #8
BRZnut
Drives: BRZ DGM Limited
When the car is hot mine does it too when I turn it off in the garage..clang clang click click and so on. More than any other car I've had.
Old 09-30-2013, 09:13 PM   #9
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Seconded the cat/heatshield comments. On cooldown it makes a lot of popping due to the temperature change. On startup it also makes noise as the car runs like -15* timing, etc to heat up the cats and get the o2's up to working temperature.
Nightbringer is offline   Reply With Quote
Old 10-01-2013, 04:04 PM   #10
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
That's just your cars way of expressing it's objection to being turned off!
BirdTRD is offline   Reply With Quote
Old 10-01-2013, 04:48 PM   #11
Silver86
Silver86's Avatar
Drives: Argento FR-S
Mine does this. Its just the metal around the exhaust cooling.
Silver86 is offline   Reply With Quote
Old 10-01-2013, 11:17 PM   #12
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Just wait till you hear the purge system running on its own, sometimes hours after the car has been shut off. Even reading the manual and knowing that it does it doesn't help the first time you hear it. It's eerie...
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 10-01-2013, 11:36 PM   #13
White64Goat
Old 10-01-2013, 11:40 PM   #14
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I'll give ya' $1200 cash for it, plus haul it off for you.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 06:58 PM
Click when stomping the gas... Brahsbrah Issues | Warranty | Recalls / TSB 13 06-24-2013 08:56 AM
Got camber? Click for lolz SubarooMike Other Vehicles & General Automotive Discussions 8 11-12-2012 01:45 AM
Click on window roll down. DantKR Issues | Warranty | Recalls / TSB 3 09-07-2012 11:37 AM
Want a first-shipment BRZ? Click here Tainen BRZ First-Gen (2012+) — General Topics 17 05-14-2012 03:29 PM
