Old 10-04-2013, 02:34 AM   #1
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
EcuTek license?
So I recently received instructions how to flash my car.. Read all the docs, queried the ecu, applied updated, ensured drivers are installed, etc.
But "Select license in the license folder"?
What license? What folder? I have the bin file and docs, but no license in the ecutek box or email or anywhere on my laptop. I don't get it.
I emailed my tuner, but was just curious if others had the same problem.
mike_ekim1024 is offline   Reply With Quote
Old 10-04-2013, 09:48 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Go to one of the top bar menu items (cant remember which one now) and selec apply license update. that prompt is supposed to get you to the folder where the license is downloaded from ECUtek server. You should see two licenses, one that ends in 0 for your tuner and one that ends in 1. Select the one that ends in one.
Old 10-04-2013, 11:22 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
When your tuner mailed you your EcuTek dongle, he should have contacted EcuTek to apply a license update to your dongle ID. Then you have to connect to the EcuTek servers and download that license update and apply it to your dongle. Then when you look at your dongle's information it should say remaining flashes 1. Then when you successfully flash the car the software will consume that flash.
Old 10-04-2013, 02:04 PM   #4
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
To apply the license, you basically just go to the options, "apply license update," then find the license file and open it. You should be automatically be sent to the folder that has the file.
If you don't see one, then you need to run the ecutek app downloader with the dongle plugged in. We have some pretty detailed info here.
PERRIN_Chris is offline   Reply With Quote
Old 10-04-2013, 02:24 PM   #5
mike_ekim1024
Thanks all, this is good info. I made sure everything is up to date, downloading multiple times. When I go to apply the license update, it does not bring me to a license folder.. there is no file there. I believe it just send me to C:\. Anyway, I tried to search my entire drive for *.upd and it doesn't exist. WHERE is this magical folder supposed to be?
Maybe my tuner forgot to update the servers.. or got the wrong information? They say the license folder appears when you click apply feature button.. well, not for me.
I've queried the ECU so I know i have the drivers and dongle key working.
Thanks much!
Mike
Old 10-04-2013, 02:44 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks much!
Mike
When I got mine from Visconti, he had not put a license on my dongle ID yet, so I had to contact him, then download the file, and then apply the license update.
Old 10-04-2013, 03:02 PM   #7
PERRIN_Chris
Thanks much!
Mike
Mike, hopefully your tuner purchased the license already. It is a possibility that they didn't though, that would explain why it wouldn't be there even if you did an update. The magical folder is in C: Ecutek - License updates - then whatever your dongle code is should be something like XX XX XX
Hope that helps!
Old 10-04-2013, 07:10 PM   #8
mike_ekim1024
Hope that helps!
My tuner got it sorted out. I just flashed it a few minutes ago.. just have to drive it around a bit to get it re-acquainted.
Thanks for everyone's help. I won't post any logs or reviews until it's fully dialed in, but maybe next week. I also want to learn more about the main parameters - AFR, Advance Timing, etc.
Mike
Old 02-23-2015, 07:34 AM   #9
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Is it possible to log any car that does not have a tune installed? Or can you only log your own car?
GeeTee86 is offline   Reply With Quote
Old 11-10-2016, 07:37 PM   #10
poolboy54
Drives: Scion FRS. Silver with black badges
Do you have to have the license to tune your car with ecutek?
poolboy54 is offline   Reply With Quote
Old 11-10-2016, 07:57 PM   #11
steve99
ecutek cable will log parameters and reset cel codes on any car. you need to open a rom of same calid as is in car so it knows what parameters to log out of ecu. No licience in ecu is required, the ecu licience is only required for flashing.
you will need the dongle key plugged into your computer though as well as obd cable, the dongle is the "licience" for the ecutek software.
Old 11-10-2016, 08:00 PM   #12
steve99
Mike
see the pretty colored links below , Click on the Ecu Logging one for some basic info.
you will need to open a stock rom in ecutek with same calid as the one flashed in you car to log or just open the one the tuner sent you , it will be locked but will activate the logging.
Where can i get an ECUtek license update? ag144 Engine, Exhaust, Transmission 2 07-25-2013 09:32 AM
ECUtek + license + cable Sniper2606 Engine, Exhaust, Bolt-Ons 16 07-18-2013 11:21 PM
ecutek cable and license questions bulldog11267mad Engine, Exhaust, Transmission 11 12-14-2012 09:01 AM
ECUTEK cable with license yomny Engine, Exhaust, Bolt-Ons 23 12-09-2012 12:02 AM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 10:34 PM
