Old 10-04-2013, 07:18 AM   #1
Moss
Moss's Avatar
Drives: Red GTS86
Fumes coming out from the vent?
Hello,
I can smell a very mild exhaust or engine fumes, Im not sure if its coming out from the front vent, or if it's the car seat heater but it is normally off, Im driving with the 2 windows open and all the vent close...I don't want to suffocate my self...annoying especially when having a long drive...car is 2 mos old, will consider changing the whole car and buy a different kind if it wont come off..While it still have its value...Does anyone have the same problem?...It a health hazard really.....
Cheers....
Moss is offline   Reply With Quote
Old 10-04-2013, 07:23 AM   #2
Moss
Moss's Avatar
Drives: Red GTS86
could be the kind of petrol I'm using, im using 98 Unleaded maybe too much high octane but that wat the spec recommend...will try 95Unleaded next time....
Old 10-04-2013, 08:08 AM   #3
Tenac
Drives: 86GTS
Hi Moss, Don't fill up with 95, only fill up with 98.
I have had a similar smell when I first drove my car hard a few times. Might be why your getting this smell on longer drives.
If you can try giving it a bit of a fang to see if this creates the smell, if it does that smell should stop in the near future and no need to sorry.
Else take it to your dealer and get them to look at it
Tenac is offline   Reply With Quote
Old 10-04-2013, 08:17 AM   #4
Moss
Moss's Avatar
Drives: Red GTS86
Thanks for the reply.......................will try that....But wat exactly do u mean bout give a bit of a fang?.....The car only done 2800km...Until when in KM. is the Break In?
Old 10-04-2013, 08:20 AM   #5
Moss
Moss's Avatar
Drives: Red GTS86
Im carefull not to Rev it over 3000RPM, until it reach 4000km in ODO....I remember I've done it (Rev more than 3000RPM) just once thou....
Old 10-04-2013, 08:28 AM   #6
Gaiseric
Gaiseric's Avatar
Drives: 2012 Scion TC
Break in is till exactly 1609.34 kilometers. Now you're driving like a grandma for no reason cause uve almost doubled your break in lol. Get that shit in gear and rip it open!
Gaiseric is offline   Reply With Quote
Old 10-04-2013, 08:37 AM   #7
Tenac
Drives: 86GTS
Ah I mean drive it hard, above 4k RPMS. You will notice you get that smell maybe the first 10 times you drive hard. I am sure the smell will go away after you do. Everyone gets it
Old 10-04-2013, 09:41 AM   #8
kevinnivek8877
Its the smell of fresh panties dropping as you drive by.
kevinnivek8877 is offline   Reply With Quote
Old 10-04-2013, 10:51 AM   #9
cnk
Drives: '13 DGM BRZ Limited
One other thing to check is the cam plate on the back of the engine. On US cars, it's on the passenger side. . .not sure if it's the same for the RHD cars though. It has been known to seep oil and that lands right on top of the overpipe and burns off. That could be what you're smelling. I had this issue on my car until I replaced it with a Raceseng plate.
cnk is offline   Reply With Quote
Old 10-04-2013, 11:08 AM   #10
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
If only they all smelt that way. ....
But seriously... Drive it the way its meant to be enjoyed, the coatings and smells will disappear quicker. I was told the first 5000kms the car will probably have weird smells from everything cooking off... I think I had mine cooked off by 2500kms
Migero86 is offline   Reply With Quote
Old 10-04-2013, 11:50 AM   #11
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Dam 95 and 98. The best i can get is 91 in AZ and that's with the 10% ethanol crap.
Kwisak is offline   Reply With Quote
Old 10-04-2013, 11:56 AM   #12
Tenac
Drives: 86GTS
Australian fuel is graded differently, Yours is RON ours is Octane. I think 91RON=95OCT and 93RON=98OCT
Old 10-04-2013, 02:32 PM   #13
Moss
Moss's Avatar
Drives: Red GTS86
Raceseng plate is that easy to install?.... how much would that be?......i assume you bought it in ebay..... Will check that out.....Thanks
Old 10-04-2013, 02:35 PM   #14
cnk
He's a vendor on the forums. It was $60.
Here's the link: http://www.ft86club.com/forums/showthread.php?t=46518
Installation is pretty simple. Remove 3 bolts, pull stock plate, clean up area with a scraper and some towels. Put 2 dabs of gasket maker in the areas indicated in the instructions, lube the o-ring, install plate and torque to 12 in-lbs. Wait 45m, then torque to 14 in-lbs. Let it sit until the gasket maker fully cures. For me, I let it sit for 48 hours since I work from home.
WTB Red BRZ/FRS fender vent. CajunFRS Exterior Parts (Aero, Lighting, Etc.) 3 09-21-2013 05:17 PM
ATI vent pod for gauge sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 2 08-30-2013 10:49 AM
SWP BRZ fender vent for SWP FRS fender vent BoxRZ_86 NY / NJ / CT / PA 4 05-27-2013 11:24 PM
frs side vent lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-02-2013 09:54 PM
hot air thru vent boonFRS Issues | Warranty | Recalls / TSB 28 09-13-2012 01:35 PM
