Drives: 2013 BRZ MT WRB
Installed header. should i do front pipe?
I have the borla uel catless header installed. Is it worth it to get a hi flow catted front pipe or just leave it stock? Gonna get it tuned in a couple weeks and i guess i should make up my mind before i get it tuned. Will i get much more power if i replace the front pipe?
#2 | |
Drives: SWP BRZ
since you got header, I would get both overpipe and front pipe together to maxmize |
i fugured that would be the answer. But what is restrictive about the over pipe?
Supra Senior Member
Drives: AE86 & BRZ
"The factory part is made from 2.118″ OD tubing (like the rest of the exhaust) and has a couple of really sharp bends along with an area with a big crimp." 2.118 to 2.5 just more exhaust gas can go away better. I believe it is most restrictive is because it bends. Like a straight pipe breath easier but throw some curve and bends you gonna have a bad time (joke)
Drives: Asphalt FRS
The overpipe honestly is not worth the money in my opinion. They make maybe 3whp with a tune if your lucky, not to mention fitment issues a lot of people have with them rubbing. I would absolutely go for a catted front pipe though, pretty decent gains with those.
Driving Enthusiast
Drives: 2013 BRZ Limited
so get the Nameless combo. $499 includes high flow cat and op.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
Drives: 2013 Scion FR-S Raven
One piece, Nameless Overpipe Front Pipe Catted with Helmholtz Resonator will flow very well and tame the rasp
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
i was thinking about berk high flow cat $250
No rubbing, I installed to a FA20club EL header
#10 |
Drives: '15 WRX '13 Legacy '07 Colorado
Another vote for Nameless. On the stock header I doubt the overpipe is worth it, it'll add a little bit and subtly change the sound, but with a larger diameter pipe off the header abruptly dropping to the smaller overpipe I can't imagine the turbulence will do anything good for you. I had to do that for a bit, and I could hear the difference, sounds vaguely "not right"
| Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? | O.Z. BRZ | Engine, Exhaust, Transmission | 22 | 04-17-2019 10:44 AM |
| Front pipe installed = WTF | solidONE | Engine, Exhaust, Transmission | 110 | 02-26-2015 07:51 AM |
| About to order HKS header & front pipe. To go cat or no cat? | BenArmstrong | Engine, Exhaust, Transmission | 21 | 06-25-2014 01:38 PM |
| PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! | Patrick@Ptuning | Engine, Exhaust, Bolt-Ons | 3 | 10-01-2013 04:16 PM |
| Borla UEL Header, Perrin 3" Front Pipe... | Taber | Engine, Exhaust, Transmission | 23 | 09-08-2013 12:55 PM |
