Old 10-12-2013, 07:46 PM   #1
Cal3000
Drives: Panda FR-S
Can I map access in ECUtek without a tune file?
I got my car dynotuned at a shop and they probably lost my tune file. I haven't found any way to map access without a tune file. Is there a way around this?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-12-2013, 09:16 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Throwing it out there... Who knows, but have u tried doing ECU query and see if the result is a flash file of the tune in your ECU?
Old 10-12-2013, 10:42 PM   #3
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
are you saying they never emailed you the flashed file? did they use your laptop to do the flashing in the first place? it maybe on there.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-12-2013, 10:47 PM   #4
Cal3000
Drives: Panda FR-S
Hmm. Haven't tried that. I do know in between dyno runs, the tuner had to upload new maps.
Old 10-12-2013, 10:48 PM   #5
Cal3000
Drives: Panda FR-S
They didn't want to email me the tune file for some reason. They used another laptop.
Old 10-12-2013, 11:09 PM   #6
jamesm
Of course. It's not like you paid for it or anything
Old 10-12-2013, 11:14 PM   #7
feldy
feldy's Avatar
fucking strange.... did they give you stock files or anything? is it one of the vendors on here? I would say they owed you a re-tune and the flashed map.
Old 10-12-2013, 11:23 PM   #8
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Hey, any EcuTek tuner should provide you with a stock rom (map) and your tuned rom.
You do need a rom file (.bin) for map access and data logging.
Let me know if your FR-S is manual or automatic, and I'll email you the stock ROM for your FR-S. At least that will give you map access and logging capability.
PM me your email address.
You need to insist that this tuner get you your tuned ROM file. Wow.
-- Bob
Circuit Motorsports is offline   Reply With Quote
Old 10-12-2013, 11:38 PM   #9
feldy
feldy's Avatar
This.... totally forgot you need that bin file to do logging. You can log a little bit with the stock rom see if you are knocking ect but the more advanced features you will need that bin file. To see things like the iam value ect.
-- Bob
Old 10-12-2013, 11:57 PM   #10
Circuit Motorsports
I can send him a RaceRom enabled stock ROM so he can datalog everything.
Old 10-14-2013, 12:41 AM   #11
Cal3000
Drives: Panda FR-S
Thanks guys. I have a stock rom file that I used. Some of the data is funky. The max manifold abs. pressure that it shows is 1.27 bar which is only like 4psi. Should be getting at least 9.1psi on the 9psi pulley. WOT ignition timing advance is reading 32 degrees. lol. I'm guessing the tune file has a lot to do with the correct readings??
Old 10-14-2013, 08:26 AM   #12
xjohnx
Grip>Slip
xjohnx's Avatar
Stock map sensor?
Help?!? Maybe..Ecutek tune JerryMichaels7 Software Tuning 6 10-01-2013 12:47 AM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-28-2013 12:56 AM
WTB: Ecutek Tune Bay area hyperpunx Engine, Exhaust, Bolt-Ons 0 04-02-2013 12:38 PM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 03:56 PM
FA20CLUB.COM ECUTEK TUNE hayleybeaners Engine, Exhaust, Transmission 21 11-13-2012 10:52 AM
