Old 10-14-2013, 10:51 PM   #1
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Dumb turbo question
I have a question which, in a way, i know the answer to but i guess im just looking for conformation. Im putting together a turbo kit and will be running an external wastegate with a ridiculously low amount of boost, 2.17psi spring controlled, and would like to know if our ecus can tolerate even this low amount of boost without a tune? this car will almost never be tracked and honestly will only be boosted for shits and gigs. If it matters, i only use 93 octane, and i live in the very cold upstate Ny.
glorydays is offline   Reply With Quote
Old 10-14-2013, 11:40 PM   #2
nelsmar
No. And it is a waste of time and money invested to only put "2.17psi". You will need to re-tune the ecu. Sure it may be "close" in the AFR tables but it is not worth the effort for the chance of a lean spot and advanced timing issues.
God forbid you are running an internal wastegate and get boost creep to 3-4psi in which you will have a major tuning issue.
My flickr - Canibeat
Local magazine scout
Old 10-14-2013, 11:49 PM   #3
mike the snake
If that's all you're looking for, why not go for the electric supercharger?
Old 10-15-2013, 02:57 AM   #4
ft_sjo
Drives: GT86
No turbocharger is happy at that boost level either.
Old 10-15-2013, 07:25 AM   #5
glorydays
Remember me?
glorydays's Avatar
Ok thanks. The 2 psi is temporary of course. Up here there aren't many tuners and even less dynos so I was hoping I could at least get things installed and drive it to a tuner and bump it to 4-5psi.
Old 10-15-2013, 08:40 AM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You can turbo charge a car and never go into boost. Just cruise on it, never WOT, light partial throttle.
The issue you might encounter is the added run length of intake piping/ change in MAF piping will be an issue idling the car because you will have no tune. The shop you plan on tuning with should be able to send you an e-tune for the turbo and then dial it in live.
Dumb question for you guys. tedddee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-26-2013 01:51 PM
Hey dumb question? FullTuneZN6 Engine, Exhaust, Transmission 4 03-06-2013 10:59 PM
Might be a dumb question about work orders oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 02-13-2013 06:46 PM
Dumb question ExWhyZer0 Electronics | Audio | NAV | Infotainment 2 01-25-2013 07:44 PM
No such thing as a dumb question? DaveFTW Issues | Warranty | Recalls / TSB 4 08-08-2012 08:59 PM
