Old 10-15-2013, 03:58 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Front Camber Bolts / Alignment Question
Hello,
Do I have to realign my car after installing front camber bolts? even with max settings?
Thanks
hanabie is offline   Reply With Quote
Old 10-15-2013, 04:10 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Yes because your cross camber will most likely be off, i.e. left and right camber do not match.
cnk is offline   Reply With Quote
Old 10-15-2013, 04:41 PM   #3
Dezoris
Dezoris's Avatar
And it will change your front toe replacing these bolts.
Short answer you need an alignment.
Old 10-15-2013, 10:38 PM   #4
fooyc
fooyc's Avatar
Drives: GT86-JDM
With just the front camber bolts what is max -ve number u all can get?
my is front -1.0deg. rear is ~-1.45
fooyc is offline   Reply With Quote
Old 10-15-2013, 11:06 PM   #5
hanabie
hanabie's Avatar
Thanks alot. I think I'm gonna get alignment after I install both front bolts and coils.
Old 10-17-2013, 05:31 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Silly question but....once installed do you immediately get say -1.0 camber? Or does it have to be adjusted (with alignment tools) to achieve the desired camber?
If the alignment work was carried out at a workshop, do they remove the wheels to adjust, then re-install wheels to check/measure again?
Fizz is offline   Reply With Quote
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Camber bolts question AceNiNe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-14-2013 10:50 AM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 10:44 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
