Old 10-17-2013, 02:18 AM   #1
jflogerzi
jflogerzi's Avatar
Recomend torque wrench
I am looking for a decent one that's inexpensive. If I am going to be dipping my wheels, replacing my header, etc... I should have one.
Old 10-17-2013, 09:32 AM   #2
FR-S Matt
Harbor Freight, you break it, you get a new one free. I don't use it enough to throw off the settings. If you want a really good torque wrench that's a bit pricier, craftsman has the digi ones.
I've got the 3/8" and the 1/2" torque wrenches. 0 issues with either and got them dirt cheap. I used them for doing my LCA's and also putting my header back on. It's a very light torque on the header surprisingly.
Old 10-17-2013, 11:33 AM   #3
frs10
Drives: tezla
are digital ones better than the non-digital ones?
craftsman would be the best brand?
frs10 is offline   Reply With Quote
Old 10-17-2013, 11:51 AM   #4
cnk
Drives: '13 DGM BRZ Limited
Just get one from HF as suggested above. If you want to research more, go to garagejournal.com and read the tools forums there. Lots of guys have had their HF torque wrenches tested and they perform just as well as the higher priced units. Just have to remember to treat your tools correctly, i.e. don't drop it, always return the torque setting to it's lowest value when you store it.
As for digital vs non-digital. It's personal preference. I use non-digital clicker units so I don't have to worry about batteries.
cnk is offline   Reply With Quote
Old 10-17-2013, 12:57 PM   #5
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
IMO, you need three torque wrenches:
1/4-drive in inch/pounds
3/8-drive in a 10 to 100 (give or take) foot/pound range
1/2-drive in a 20 to 200 (give or take) foot/pound range
There is also 3/4-drive in a 50 to 300 range, but unless you are working on diesel trucks, you wont have much use for it.
If you can only afford one, the 3/8 is the one to start with. I have always had good experience with Craftsmen and Snapon tools. Booth have a lifetime warranty. DO NO BUY TOOLS FROM Harbor Freight. They will piss you off and you'll end up buying one of the above brands anyway. Buy Once, Cry Once.
Digital vs non-digital, I prefer the non-digital. What ever model you get, only store it set to zero, otherwise it will loose its calibration over time.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-17-2013, 01:25 PM   #6
Buy two harbor freight torque wrenches when they have the $10 off coupons.
Constantly interchange, them, and if they don't agree at any time, exchange both.
They normally retail for $25.
Alternatively, get a beam type and call it a day; those don't go out of calibration unless you abuse them.
Old 10-17-2013, 02:13 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have a beam type TW. Works awesome.
Old 10-17-2013, 03:12 PM   #8
cnk
Incorrect. Craftsman only offers 90 day warranty on torque wrenches: http://www.craftsman.com/cswarranty/...227082#point3a
While I agree that I wouldn't buy most tools from HF, their torque wrenches are fine. Like I said, do your own research on them first as they are accurate and within tolerances of other manufacturers. For the price of a Snap-On I could replace my HF one every year for the next 30-40 years. But if spending the money for a logo/name makes you feel better, it's your money.
Old 10-17-2013, 03:23 PM   #9
While I own a lot of Craftsman and a few Snap-On pieces, I also own a lot of Harbor Freight, and I've yet to have ANYTHING from Harbor Freight fail on me with proper maintenance...
I also regularly check my two HF torque wrenches against a snap-on, and they've never lost their torque. I even leave one permanently at 80; I never back that one off.
I did have a Craftsman torque wrench fail on me last year, and that one cost me a few hundred bucks =\
Old 10-17-2013, 03:36 PM   #10
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Like mike said we have tested HF tongue wrenches with snap on wrenches and have not found any problems. Take care of it and use it for what it's intended for, you will be fine. Our track side tool box is mainly made up of HF tools way cheaper to replace of they walk off.
DAMotorsports is offline   Reply With Quote
Old 10-17-2013, 04:09 PM   #11
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
This looks neat: http://www.harborfreight.com/digital...ter-68283.html
I have a house brand one from napa/pepboys/etc in 1/2" . I should test it. It's the clicker type. I also have a 1/4" beam craftsman for lighter things (like top hat bolts).
robot is offline   Reply With Quote
Old 10-18-2013, 09:55 AM   #12
frs10
Drives: tezla
what specific applications do we need a torque wrench for while working on our cars?
why not just a regular ratchet set?
Old 10-18-2013, 07:24 PM   #13
Gary in NJ
Gary in NJ's Avatar
Every nut on the car has a torque value. Many shade-tree mechanics would just advise "just make it tight" but "tight" is an unknown value. As someone who works on aircraft and motocross bikes, it is unacceptable not to properly torque a fastener. Not only do you run the risk of loosing the fastener (resulting in failure or an accident) but just as bad is an over torqued nut. Just ask someone that has had to remove an over torqued oil drain, lug nut, suspension component, etc...
Old 10-18-2013, 08:09 PM   #14
frs10
Drives: tezla
ads
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 01:46 AM
Brownline digital torque wrench qoncept Mechanical Maintenance and Tools 0 06-28-2013 12:20 PM
Torque Wrench options FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 03-14-2013 03:29 PM
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 06:30 AM
Which type of torque wrench do you prefer? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2012 05:17 AM
