Drives: Grey GT86 MT
Issue with Kartboy short shifter
I'm not sure where the correct location to post this as my communications with tom@kartboy appear to have broken down. I can noticeably wobble the shifter from side to side when in gear apparently it's due to faulty bushings but whether it's the rear shifter or a bushing inside the shifter I don't know. Can anyone shed some light on how I can fix this?
Drives: '13 DGM BRZ Limited
I've got a BPS short shifter and you can move it side to side while in gear. It did this stock as well. I think you're just being paranoid after you swapped shifters. If you want to test it out, put the stock one back in and I bet you still get the movement.
Drives: Attitude
That's a design flaw with the trans shifter assembly (the parts you don't replace with any kit). There is noticeable side to side play while in gear on my stock shifter.
Bang Bang
Drives: 2013 Raven FR-S
Does that mean that the twm version would possibly take care of the wobble feel?
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers |
Bang Bang
It claims no rattles. The design is a little different. http://www.twmperformance.com/shorts...rtshifters.htm
Sent from my HTCONE using Tapatalk
#7 | |
Bang Bang
I see....
Cheers for the replies but I coulda sworn it wasn't like this when it was first installed. But at least now I know what I've been experiencing is normal.
| KartBoy Short Shifter DIY and Review | F1point4 | DIY (Do-It-Yourself) Guides | 274 | 06-02-2017 06:48 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Transmission and Driveline | 16 | 04-18-2013 02:18 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Announcements, Contests, Giveaways | 34 | 03-18-2013 03:18 PM |
