Old 10-21-2013, 08:03 PM   #1
autoCAR
Drives: 5/2013 scion frs
HELP i think i cross threaded subframe mounts
I'm about to cry. I was hand tightening the bolts that hold the rear subframe after installing the rear whiteline bushings n it just stopped. I can't turn it at all after about a half inch. I took the bolt out and there's metal shavings on it. Omg what do I do
autoCAR is offline   Reply With Quote
Old 10-21-2013, 08:10 PM   #2
TOZER
Drives: 2013 Whiteout FR-S
The car is destroyed. Might as well sell it
TOZER is offline   Reply With Quote
Old 10-21-2013, 08:21 PM   #3
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
http://www.ehow.com/how_7571380_repa...ded-bolts.html
Sent from my SGH-M919 using Tapatalk
ProTekk is offline   Reply With Quote
Old 10-21-2013, 08:34 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
probably stripped it, if you don't have the tools for repair, take it to a shop
Old 10-21-2013, 08:35 PM   #5
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
You can try a long tap so you don't have to remove anything.
I actually bought one of below to clean up a tread, mind you this tap took a few weeks to come in:
http://www.ebay.com/itm/271151671881...4.m1497.l2648#
Hope that helps.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 10-21-2013, 08:39 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the problem is not even that you stripped it
its why you stripped it
the answer to which is that when you were re-installing it, there was uneven torsion on the frame.. or similar and the subframe wasn't perfectly aligned with the chassis
this is a real pain in the ass. Not a problem under shop conditions where the frame is evenly supported, but if you were doing this on jackstands, there is a good chance you had it mis-aligned as you were torqueing it down.
Old 10-21-2013, 08:49 PM   #7
autoCAR
thanks, I'm going to try to get a tap now. I don't think local parts store will have this size. I'm gonna have to bring it to a shop to get them to fix it I think.
Old 10-21-2013, 08:50 PM   #8
autoCAR
car is on jack stands, that probably why it happend. Only back is up which is messing everything up
Old 10-21-2013, 09:44 PM   #9
SonnyBRZ
SonnyBRZ's Avatar
Exactly as what 7thgear have said.
Once you have the bolts undone, the subframe "misaligns" slightly. I had to use jacks to bring up the subframe / loosen the other bolts to align it.
Make sure you just use your fingers to get the bolts in and have at least a few turns before using a ratchet. You could look into the hole to see if it is align or not, but more importantly, go by feel and that is using your hands to get threads started. If it doesn't go in, stop and try to realign.
Good luck and hope you get your car fixed soon.
Old 10-22-2013, 12:55 PM   #10
autoCAR
thanks for the info guys. Cars at a shop now, the mechanic said its actually not that big of a deal, and that he fixed those threads before. I got my fingers crossed that I get my car back quickly with no complications.
Old 10-23-2013, 06:31 PM   #11
autoCAR
just an update, cars fixed n I'm driving it. Mechanic said I'm lucky, 2\3rds of the threads were still good. He removed the whole subframe retapped the sheeread threads, reinstalled everything w the bushings, and he said "do yourself a favor, don't ever take these bolts out again"
Old 10-23-2013, 06:45 PM   #12
NemeGuero
what'd he charge you for all that? just curious
NemeGuero is offline   Reply With Quote
Old 10-24-2013, 12:13 PM   #13
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Every time I do the rear subframe bushings I have to be super careful putting the bolts back in, and always double check the alignment of the subframe. For some reason these particular bolts seem to want to cross thread more than any other bolt on the car haha. Glad you got it fixed, and this is the exact reason I have plenty of taps and thread chasers whenever I work on something lol.
This should be a good warning to anyone doing these bushings. Just be very careful putting those bolts back in
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 10-24-2013, 06:57 PM   #14
autoCAR
he is a friend of the family, and he saw I was genuinely upset about the whole thing, so he didn't charge me. I tried leaving him 100 bucks but he didn't take it
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 01:29 AM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 12:24 PM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 10:20 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 11:53 PM
