Old 10-22-2013, 01:18 PM   #1
Weeber
Drivers side pillar rattle! (With links)
Hi guys
372miles
Rattle on drivers side B pillar (RHD)
https://soundcloud.com/brze/rattles
Has anyone experienced this before?
Weeber is offline   Reply With Quote
Old 10-22-2013, 10:44 PM   #2
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
My A pillar is rattling (driver side) only at certain rpm. It gets annoying so next time when i go to the dealership i will raise my concern with the service manager.
Muaddib is offline   Reply With Quote
Old 10-23-2013, 07:53 AM   #3
frosty86
frosty86's Avatar
Drives: '13 FR-S (Whiteout) Manual
I know this issue, it's happening to mine too.
I took it to the dealer but the mechanic couldn't quite put his finger on it. I'll be returning the car to them soon to see if they can get it this time.
frosty86 is offline   Reply With Quote
Old 10-23-2013, 09:34 AM   #4
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Mine does it.
jadewbj is offline   Reply With Quote
Old 10-23-2013, 01:27 PM   #5
tomkozski
Drives: 2017 WRB BRZ w/ PP
Sound can travel funny in a car. Check for a somewhat loose wire bundle under the dash, left of the steering wheel, behind the fuse panel. I had a similar noise, and discovered that it was that wire bundle.
tomkozski is offline   Reply With Quote
Old 01-09-2016, 01:52 AM   #6
Zhangy
Drives: 2015 FRS
mine does this... so annoying
Zhangy is offline   Reply With Quote
Old 01-09-2016, 03:23 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
While the car is moving and making that noise, start pushing on panels to see if it stops to narrow down the location and cause
Old 01-09-2016, 05:31 PM   #8
Side
Side's Avatar
Drives: 2018 BRZ tS
Mine only rattles when my subwoofer is going, even on low haha
Side is offline   Reply With Quote
Old 01-09-2016, 05:41 PM   #9
BRZnut
Drives: BRZ DGM Limited
mine did that too. A little clear caulk at the seam between the upper and lower plastic piece stopped the rattle, and that was 2 years ago! Still nice and quiet
Old 01-02-2020, 03:15 PM   #10
Suparu
Drives: 2013 BRZ Limited
Resurrecting an old post in case this helps anyone.
My passenger side A Pillar has been rattling when going over bumps. I pulled it off as far as the airbag wiring etc would let me, and saw one pop clip in the middle of the pillar. I smothered the pop clip and the hole it goes into with white lithium grease. That stopped the rattling for me
Suparu is offline   Reply With Quote
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 11:20 AM
Drivers side marker clips. feldy Cosmetic Modification (Interior/Exterior/Lighting) 21 05-08-2015 03:43 PM
Rattle in drivers side headliner-help! meadowz06 Issues | Warranty | Recalls / TSB 5 09-18-2013 11:44 PM
WTB: Broken BRZ Drivers side Headlight Lee358 Exterior Parts (Aero, Lighting, Etc.) 0 03-26-2013 04:53 PM
Placing side mirrors inside a car, on the A-pillar hotaka Scion FR-S / Toyota 86 GT86 General Forum 11 08-08-2012 01:19 PM
