Old 04-18-2012, 07:32 AM   #1
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
6000k Halogen bulbs?
Since the FRS doesn't come with HID...
Will the FRS get a white light projection with 4300k-6000k Halgen bulbs in the projector housing?
CyberFormula is offline   Reply With Quote
Old 04-18-2012, 09:17 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It'll get clear bulbs. 3500k or whatever halogen is. I forget these days.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 09:31 AM   #3
CyberFormula
so you think there is an aftermarket bulb out there that will make a better white color than the stock halogen..that's yellow 3500k?
Old 04-18-2012, 09:36 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep, but like high temp HIDs they produce less lumens because the glass gets colored.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 06:53 PM   #5
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
The only thing I can see happening is a H11 to H9 "conversion."
Basically ups the wattage of the housing a bit. You have to modify the H9 bulb.
It's brighter a little whiter but bulbs go out quicker. But the bulbs are relatively cheap as well.
Lumen output is about 750+ better, but still lower than good OEM HIDs.
http://www.candlepowerforums.com/vb/...-and-H11-bulbs
My wife's Prius has halogen projectors and they are pretty white and actually pretty decent stock.
But this is all dependent on if the housing on the FRS is H11 and if the H9 bulbs will even work.
86'd is offline   Reply With Quote
Old 04-18-2012, 07:10 PM   #6
R0ME0
ハチロク
R0ME0's Avatar
Drives: Evo X
Do the stock FR-S come with H11?
R0ME0 is offline   Reply With Quote
Old 04-18-2012, 07:21 PM   #7
86'd
86'd's Avatar
AFAIK, yes:
http://www.ft86club.com/forums/showp...0&postcount=56
Originally Posted by Jeff Lange View Post
Low Beam (Halogen): H11
High Beam (Halogen): 9005
Low/High Beam (HID): D4S
Fog Lamps: PSX24W
License Plate/Markers/Parking Lights: W5W / 194
Turn Signal Bulbs (F/R): WY21W / 7440A / 7440NA
Reverse/Back-Up: W16W / 921
Brake/Tail Lamp/High-Mount: LED
Door Courtesy Lamp: T10
Dome Light: T10
Trunk Light: W5W / 194
Jeff
Old 04-18-2012, 08:40 PM   #8
MRZ415
Drives: 2015 Subaru WRX
I have H7 Osram Rally Halogen which use an H9 burner,
not as bright as HID but puts out a decent amount of light.
I would NOT go 6000K temp since you loose light output,
but rather if you want to go HIDs go with 5000K max (stay classy).
MRZ415 is offline   Reply With Quote
Old 04-22-2012, 04:41 AM   #9
CyberFormula
But I want slightly rice man. :/
Details: Interior dims, glass, light bulbs Ryephile Scion FR-S / Toyota 86 GT86 General Forum 17 03-01-2012 11:28 AM
