| CANADA Canada |
Drives: Subaru BRZ Sport Tech Satin White
Power window auto drop fault ?
Posted this in the warranty thread also.
Seems likely to be a Canadian market type fault, if it is a fault. The passenger side window dropped down halfway when the door was opened, instead of just an inch. Then the power window switches flashed in fault mode. The auto up function was disabled as if the window had auto reversed. Resetting that BTW is easy, just put the driver or passenger side window all the way down, then raise it by holding the up switch, holding it for a few seconds after the window is fully up. Window switches stop flashing and the auto up/down works again. Anyone else had this fault show up? |
Drives: 2013 Subaru BRZ Sport-Tech
Yip ... just happened a few days ago ... must be due to the colder weather and the anti-jam function.
Cheers, Zoomby_U |
#3 | |
| Auto-Up/Down and Passenger Window Not Working | chanomatik | Issues | Warranty | Recalls / TSB | 106 | 05-09-2021 02:25 AM |
| Power window fault in cold weather | Suberman | Issues | Warranty | Recalls / TSB | 5 | 01-09-2014 10:24 AM |
| Stop window auto scroll | Rumbaar | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 08-27-2013 07:44 PM |
| FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM | zetaproducts.net | Interior Parts (Incl. Lighting) | 28 | 05-14-2013 10:32 AM |
| Auto up and down window Issues? | CzRceCar | Issues | Warranty | Recalls / TSB | 3 | 08-07-2012 08:44 PM |
