| Southern California SoCal |
Drives: Scion FR-S
Local custom exhaust
Anyone have a recommendation on someone local that can fabricate a small piece of the exhaust for me? (San Diego) I had to tilt my radiator back in order for everything to fit on my turbo setup. The downpipe is ever so slightly touching the fan, and it won't last forever like this. I need someone that can fabricate something straighter. It would also be nice to use some larger fans, as the slim fans don't really do the trick in the hotter months.
Drives: 2013 Scion FRS "Raven"
What turbo kit are you running
Hit the guys up at Performance Tube Bending, solid work from them.
Drives: Scion FR-S
FBM. The pipe has this wonky curve, presumably to give the MAF ample room. Once you start adding things up front, it becomes problematic. It all fits fine with the stock radiator, but that's not really up to the task of a turbo charged car. There's also a 25 row Setrab oil cooler up there, so it's all a tight fit.
#6 | |
Drives: Scion FR-S
The bad about tilting your radiator back is it changes the air flow design. You might be better off changing to a one piece unit for cooling both oil and water. Now sure if you have thought about that. You can also move the oil cooler and make a ducting for air flow
#8 | |
Drives: Scion FR-S
| shop/local installing MXP exhaust catback & front pipe | jgonx213 | Southern California | 7 | 11-06-2013 03:55 AM |
| Brand new AFE exhaust for local pick up | genometuning | Engine, Exhaust, Bolt-Ons | 25 | 09-17-2013 01:22 AM |
| MD: ARK GRIP EXHAUST $800 (LOCAL) | Ric Flair | Engine, Exhaust, Bolt-Ons | 7 | 07-28-2013 11:38 PM |
| Anyone local with aftermarket exhaust yet? | Areddi | Mid-Atlantic | 20 | 09-13-2012 08:40 PM |
