| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: FR-S 10 #103 AT
question: how to remove rear seatback?
I'm sure this is written up somewhere as part of a bigger write up, but I can't find it. Can someone please point me to it?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
Drives: '24 GR86
Fold down seat, pull bottom part of carpet covering the back of the seat up and discover a bracket with a bolt on it on each side. I belie it's a 10mm or 12mm. Unbolt them. Then pull the brackets off the metal tab you see next to the bolts and it'll come right off.
The bottom of the seats come off with the one bolt on each side and a metal clip to unhook which is super easy. I just did this over the weekend and it took no more than 5 minutes from beginning to end.
#3 | |
Drives: '24 GR86
They'll come off. Pull harder lol
Now how does the center portion of the seat come out?
Drives: 13 DGM BRZ Ltd
How thick is the pad? It looks worth taking out if you want to do something in that area.
You will need to clarify your questions more if you want help. Pictures would also help.
The piece that sits on top of the transmission tunnel. I want to take it out. I knew how to get the buckets out, now I know how to get the seatback out. Last bit is the piece sitting on the transmission tunnel.
#10 |
![]() That piece? |
#11 |
That is it exactly. It looks like it extends a little under the center console and might have an attachment point under there. I really don't want to remove the center console if I can avoid it, although I have plans that will require it eventually. If it has to come out, I'll do as much prep work as I can and do both projects at once while it is out.
#12 |
http://www.ft86club.com/forums/showthread.php?t=25957
You need to remove rear seat bottoms and center console, then pop out 2 tabs to pull that piece out. |
#13 |
Drives: 2013 Subaru BRZ
do you guys know how much the rear seats weigh?
#14 |
Drives: MKVI VW GTI
| How-To: Remove Rear Deck & Third Brake Light | Moshpit37 | DIY (Do-It-Yourself) Guides | 63 | 08-01-2020 10:48 PM |
| [Question] How to remove stains from rustproofing | i_4got | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 05-01-2013 05:59 AM |
| Best way to remove the Scion Rear Bumper Applique? | Tim_Asphalt_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 12-25-2012 02:30 AM |
| will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 11:41 PM |
| TRD Rear Lip question/opinion | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-18-2012 02:50 PM |
