Old 11-24-2013, 06:38 PM   #1
Anthony7515
brz owner
Drives: 2013 Subaru brz white
how many miles before first oil change
i have 1150 miles on my brz when should i do my first oil change should i have done it sooner with the break in pierod
Anthony7515 is offline   Reply With Quote
Old 11-24-2013, 06:56 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
first one @ 7500miles and second at 15000miles
Dr. BRZ is offline   Reply With Quote
Old 11-24-2013, 06:57 PM   #3
Dr. BRZ
Dr. BRZ's Avatar
its a boxer, so oil change every 7500 miles.
Old 11-24-2013, 09:34 PM   #4
a2cpc
Drives: WRX
It won't hurt it to change it earlier.. I have had mine changed at 1500 on every new car I have had. It is a peace of mind thing for me, but it doesn't HAVE to be done, but it won't hurt.
a2cpc is offline   Reply With Quote
Old 11-24-2013, 09:49 PM   #5
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Changing the oil too often might not be that great either...
http://www.bobistheoilguy.com/forums...Number=1900212
993Fan is offline   Reply With Quote
Old 11-24-2013, 09:56 PM   #6
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Actually, it could. The oil in factory new engines contains an oil additive to help with break in.
Stick to the factory recommended intervals.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-24-2013, 10:45 PM   #7
kbogarto
Drives: 2013 BRZ limited WRB
Thanks for the info i did not know that. Makes sense though.
kbogarto is offline   Reply With Quote
Old 11-24-2013, 10:59 PM   #8
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
7500. I was a couple hundred short and the mechanics at Toyota couldn't do it.
Kelbyat07 is offline   Reply With Quote
Old 11-25-2013, 01:26 AM   #9
WoOosOn
WoOosOn's Avatar
Drives: S2000 AP1, BRZ SWP
i have 1100 miles on mines, but im going to track my car in a month should i change it before or after?
WoOosOn is offline   Reply With Quote
Old 11-25-2013, 01:46 AM   #10
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
I did it right around your miles.
bkblitzed is offline   Reply With Quote
Old 11-25-2013, 02:39 AM   #11
suaveflooder
I did mine at 3000, although, it would have been totally fine at 7500
suaveflooder is offline   Reply With Quote
Old 11-25-2013, 02:44 AM   #12
sierra
Drives: Skoda Yeti DSG diesel 4x4
I changed mine at 6000km and it was far too late. The oil was thin, black and burnt.
Since then it's been fine with the oil remaining clean for a long time and zero consumption.
If you ran it in the right way, fast, on reflection I would have changed it at 2000km, about where you're at now.
sierra is offline   Reply With Quote
Old 11-25-2013, 02:48 AM   #13
bkblitzed
is better than you
bkblitzed's Avatar
I did mine around 1500 and I had flakes and the oil was pitch black. So I would do it soon
Old 11-25-2013, 03:53 AM   #14
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Subaru recommends changing it every 7500 miles or every 7.5 months right? I'm getting close to the 7.5 month mark and not even close to 7500 miles.
eSOLOR is offline   Reply With Quote
some idiots post here, stock oil is synthetic
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 01:31 PM
oil change at 1000 miles! thoughts? ric342 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 05-23-2013 11:37 AM
Oil change at 1000 miles. Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 03-08-2013 05:18 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
When to change the oil Capstan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 10-11-2012 03:41 PM
