Drives: 2013 BRZ Limited manual
direct injection cc size
i am looking to find out how big each direct injector size is. im looking at adding a aquamist methanol injection and trying to calculate my jet sizing i would need but i need to know the injector size.
thanks for any help you can give me.
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
Not sure about the size, but they only come in one size. It's the port injectors that people install bigger versions of depending on modifications to the engine and fuel used.
I have a FBM premium turbo kit with 550cc injectors. But for calculating the correct size sprayers I need for the methanol I need to know my total injector cc. I have 550cc port injectors so that's 2200cc total for that but I also need to know the direct injector size to get an accurate calculation.
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I was trying to scour for the information literally yesterday, not easy to find. The first clue I found was was the Bosch DI system has a fuel flow rate of 22.5 cc/s @ 10 MPa.
still looking for the DI cc size per injector.
Drives: 2013 Asphalt FR-S
What you really want to know is the flow rate not the size... DI flow rate changes with rail pressure which is variable on our setup. you should be able to to get a close enough calculation based on the target hp, afr on pump gas, and engine size.
Then just get a few jets that are close to your desired mix ratio and try them out to see what works best, thats what your gonna need to do anyway. http://www.deatschwerks.com/resource...tor-calculator
~Namaste~ |
| Direct injection/port injection explained? | mike the snake | Software Tuning | 31 | 06-06-2021 07:17 PM |
| Stock Direct Injection PSI | Fenrir | Engine, Exhaust, Transmission | 18 | 05-17-2013 04:03 PM |
| ever seen fuel injection like this? | carbonBLUE | Other Vehicles & General Automotive Discussions | 1 | 10-17-2012 03:17 AM |
| Gasoline Direct Injection... | DoogenBurns | Engine, Exhaust, Transmission | 5 | 05-21-2012 03:05 PM |
| Photos of Subaru Boxer 1.6L Direct Injection Turbo DIT Engine from 2011 TMS | Hachiroku | BRZ First-Gen (2012+) — General Topics | 21 | 12-01-2011 08:52 AM |
