Rubber smell sometimes on cold start
Anyone else notice a strong rubber smell when starting the car in the morning in cold weather? It happens as soon as I start the car and before I even begin to move. After a minute or 2 of driving, it goes away completely.
Any ideas? I should note that the only mods I have are an Invidia fp, Invidia N1 catback, an AEM intake and a stage 2 FA20Club tune. |
#2 | |
However, I always have an idea (most of which don't work); you might check the serpentine belt tension when it's cold .... before you crank er up. Maybe the tensioner pulley sticks a bit when it's cold .... ![]() humfrz |
Well, honestly, it wasn't like that from the factory and it didnt start happening until I installed my exhaust and tune (did at about the same time, so not sure exactly when it happened). I can't imagine either of those having anything to do with this, though so I am at a loss.
Drives: Whiteout FR-S
I have the same smell! Only when air is on. Not so much rubber as plastic? Mix of the two? I can't figure it out. Had my exhaust on for a couple months now and been fine in other cold-weather. Just today.
Hmm... I never really paid attention to if the air was on when it happened...
Sent from my Nexus 4 using Tapatalk |
Called a Toyota tech. Said it might be transmission fluid leaking on the exhaust
Well, mine definitely doesnt smell like tranny fluid and there are no drips, so that's not the case for me.
Drives: Fast
Some new exhaust will smell for awhile until they are broken in. They are covered in a light oil to revent corrosion.
Also, look for plastic on they system, you may have run over a plastic bag and it's melting. |
#9 | |
Drives: 2013 Subaru BRZ
I would lean more towards the tensioner/belt theory. Is there any belt squeal, even just a brief chirp, when the car is started? |
#10 |
Its def not the exhaust oils. I had that for a while, but its gone now. There is 0 squeak or squeel on startup
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Burnt Rubber smell | Fizzle | Issues | Warranty | Recalls / TSB | 22 | 01-06-2013 10:10 PM |
| Anyone else smell rubber? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 15 | 09-24-2012 04:40 AM |
