Drives: Scion FR-S
Winjet Headlights and HIDs
Has anyone made this work yet? Iv got the lights installed but I'm totally confused as to how to wire up the HID kit. It's a diode dynamics kit. Any insight would be greatly appreciated
Ridge Racerrrrrrrrr
you install the HID kit like you install ANY HID kit. so just find instructions for that. the unit is dual Hi/low from what i understand but that is controlled by a solenoid and not the bulb so you could just google around and get there.
Drives: Scion FR-S
It's the harness that's got me confused. Because the the high beams and LEDs use the oem connector. I can't see how the solenoid and the LEDs would get their power
#4 | |
Ridge Racerrrrrrrrr
I think? Logically I would assume taht is how it works.
Drives: Scion FR-S, Whiteout
Do you have any pictures of the wiring? Anyway, the way i have my relay harness wired is essentially to the car battery, one side wires up go the oem switch for low beam and powers the ballast, while the other side goes to the other ballast and ground. High beams are still using stock oem harness. I dont have winjets but if you want to take a few pictures of the wires maybe we all can help.
Is the HID kit a plug and play kit? If it is, all you should have to do is plug the ballast into the stock bulb plug, mount the ballast, plug the bulb into the ballast and put it in the housing.
By the sound of it you shouldn't have to touch the LED or highbeam side of this at all to put in the HID's.
#7 | |
Drives: Scion FR-S
Right, here's the thing though, the stock lights have the 6 pin connector, then spilt to the high/low beams. The winjets have their own harness that replaces the one from the 6 pin connector to the bulbs |
Ridge Racerrrrrrrrr
I would talk with Ft86 speed factory, I think they are installing HID kits in theirs, should know how to do it.
Sorry I cannot help out more yet
#9 | |
Stealth
Drives: Ultramarine FR-S
Figure out which wires power the LED's, now just ignore those since you want the projector power wires. Brown wire is your ground. I think the projector ones were black and white wires. I spliced those and hooked them in with my wires that went to my HID ballasts with wire nuts and black electrical tape. Those will send power to the ballast and on to lights. Not sure which color connects to which, my ballast wires were black and red (might be different for you). Hope this helps. |
#10 |
Look for the part of their harness that goes to the low beam bulb, then tap into that for power to the ballast.
#11 |
Drives: Scion FR-S
#12 |
Drives: 2013 FR-S, 2012 MCS
Typical HID PnP kits are (almost) idiot proof. Ide like to see a pic when you get it figured out
#13 |
Drives: Scion FR-S
Okay. Simple enough. Not quite plug and play. The 6 pin connector needs to be repinned on the headlight side from the low beam wiring that comes on the winjets to the low beam wires that are oem. Then that can get connected to the ballast, then to the lights. No splicing necessary. Just switching those two sections of harness
#14 | |
Drives: The silvertrooper 10 series
If you need any help you can contact us. |
| *** Winjet Projector Headlights & LED Taillights - IN STOCK @ Sonic Motor *** | Sonic Motor | Exterior Parts - Lighting | 500 | 07-29-2016 03:15 PM |
| Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 03-25-2014 12:08 AM |
| Winjet JDM Style Headlights Groupbuy --> Round 2 Now Open!! | 86_ZN6 | Groupbuys | 206 | 02-13-2014 06:45 PM |
| Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 09:28 AM |
| Norcal GB: Winjet JDM Style Headlights | 86_ZN6 | Northern California | 2 | 12-11-2013 04:31 PM |
