Old 04-26-2012, 03:07 AM   #1
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Widest Track tires for stock wheels??
I was thinking with going with some federal 235/45/17 rs-r racing for the stock wheels. Do you guys think it is to wide for the stock wheel?
Found them for dirt cheap
https://www.onlinetires.com/products...g+94w+bsw.html
track_warrior is offline   Reply With Quote
Old 04-26-2012, 09:49 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
For the tire federal says 7.5-8.5" wide wheels with an 8" wheel suggested. It'll probably fit but you'll ballon the tire a bit. A 215 or 225 would likely function better.
That's a street tire not an r comp, you were aware of that correct?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-26-2012, 06:47 PM   #3
track_warrior
Track Junkie
For the tire federal says 7.5-8.5" wide wheels with an 8" wheel suggested. It'll probably fit but you'll ballon the tre a bit. A 25 or 225 would likely function better.
Yup but they are grippy plus you cant beat the price. I think they will have enough grip for a car this light plus they are dirt cheap.
Old 04-26-2012, 07:21 PM   #4
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
I can't speak to it's value, but there is a good amount of unflattering info on the 595's at s2ki.com (http://www.s2ki.com/s2000/topic/8391...gestone-re-11/) and the S2000 is pretty much the same weight as the FR-S/BRZ.
OTOH, the overheating comments seem to apply to track days - you don't really say what you intend these for - and they are really inexpensive - might be worth testing yourself.
I agree that you will probably end up just as quick with a 215 or 225 on 7" vs 235 on 7"
jdrxb9 is offline   Reply With Quote
Old 04-27-2012, 11:30 AM   #5
Biggins
Drives: Yes
They're cheap because they're garbage.
215 or 225 Hankook RS3s are only slightly more expensive and worlds better.
Biggins is offline   Reply With Quote
Old 04-27-2012, 11:34 AM   #6
Aonarch
Sup Brah?
Aonarch's Avatar
Drives: '12 VW GTI
Agreed.
To a point you get what you pay for.
I love Star Spec's and Hankook V12's.
Aonarch is offline   Reply With Quote
Old 04-27-2012, 11:53 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tires on the only thing connecting the car to the road so I can't suggest cheaping out on subpar tires. I've never used the Federals so I can't comment but some reviews I've read, and the posts here, show that they aren't great tires.
I'd rather run RE11s, Star Specs, RS3s, XS, etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-27-2012, 11:57 AM   #8
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
it frustrates me to no end the way people want to cheap out on the two most important safety items on a car: tires and brakes.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-27-2012, 12:42 PM   #9
colHolm
Default User Title
colHolm's Avatar
Agreed. I've only in the last couple years been able to convince my immediate family of the benefits... I never understood why such a simple concept seemed so dificult to grasp? I guess for a lot of people basic maintenance and upkeep for their cars is a "grudge" purchase.
colHolm is offline   Reply With Quote
Old 04-27-2012, 01:09 PM   #10
track_warrior
Track Junkie
I have ran 2 sets of these tires on my c63 and 1 set on my 240sx and i have ran nt-05's as well. I track my cars every month since i am a member at my local track and i have had no problems with the federals, they seem to perform the same as the nittos except they last longer and are cheaper. If they can handle a 3700 pound car they should have no problems with a 2600 pound car.
It frustrates me when people speak when they have no experience over something.
Since im buying this car as a track only car meaning it will be stored in my garage at at my local track i need to save money as much as i can since i will be tracking it at least once or twice a month meaning i go through a set of tires every 2 months or sometimes less. I am not competing profesionaly so i dont care if they give me .2 seconds of a lap slower than higher and more expensive tires.
Old 04-27-2012, 01:13 PM   #11
track_warrior
Track Junkie
repost sry
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
Old 04-27-2012, 01:33 PM   #12
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
So to get back the original title of this thread, is a 225/45-17 the widest recommended tire for a 7" rim?
I understand that actual width varies somewhat from one brand to another, just looking for a general guideline.
Klinn is offline   Reply With Quote
Old 04-27-2012, 01:59 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
In general 215s rec a 7" wheel. 225s usually on a 7.5" wheel but will fit on a 7" wheel of course.
Depends on the aspect ratio too.. check the specs for your preferred tire, the info is all there.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-27-2012, 02:14 PM   #14
jdrxb9
jdrxb9's Avatar
None of the rim width range specs for the 'extreme performance' 'street' tires (R-S3, AD08, R1R, XS, RE-11, Z1SS, 595RS-R) show a 7" wheel for anything wider than 225 (unless there is something wierd in non-17" or non ~25" OD I didn't look at).
Some more food for thought from multi-time SCCA champion Andy Hollis quoted from his FAQ here: http://www.cicenet.net/showthread.php?t=11708 (the original page is maintained on FB, which I won't link to : )
Optimal wheel size
Many folks entering the ST category are refugees from Stock looking to make some performance upgrades to their car and/or reduce their tire budget. Unfortunately, they carry with them some baggage on concepts that may work well in Stock, but not in ST. One of these is optimal wheel/tire fitment.
Since Stock limits you to the OE wheel sizing, astute competitors have learned how to stuff increasingly wider tires onto those skinny rims. And tire makers have been happy to make wider and wider tires, likewise charging more and more money. But, is wider better? In Stock, the answer is often "yes". The sidewalls on these DOT-approved "Not for Highway Use" R-comps are super stiff and allow for "overtiring" much in the way that a cantilever style slick works to get around wheel width limitations for formula cars.
In ST, drivers in most classes have limits on both wheel width and tire section width, both of which are much wider than OE. The tendency is to cram the widest legal tire on the widest legal rim that will fit and go for it. But that is not always the optimal solution, as street tires do not have the same super-stiff sidewalls as do the best R-comps. Sometimes it makes sense to run a narrower tire for a given rim fitment. From the testing we've done, we find that a good rule of thumb is that the optimal rim is the same size (rounded up to the nearest half-inch or so) as the tread width (not section width!). So a 205/50-15 tire with a typical tread width of 7.5" is best on 7.5" rim. An 8" rim will work, too, but it will be majorly stretched on a 9. Likewise, it will lose some performance on a 7, and will lose a LOT going down to a 6 or 6.5. Similarly, a 225/45-15 with an 8.2" tread width works best on at least an 8.5" rim and loses a fair bit on a 7.5".
A practical example of this is in STC, STF and STS where the rim limitation of 7.5" keeps the 195/50-15 Toyo R1R at the top despite it not being the widest allowed tire size. The 225/45-15 R-S3 mounted on that same 7.5" rim is not quite as fast. But put that same R-S3 on an 8 and it comes alive. And it's even better on something a bit bigger. So in STR, where wider rims are allowed, the common 225 R-S3 on 9's is a faster combo than the 195 R1R on a 7.5 (assuming nominal weather). And putting the 195 on an 8 or wider does nothing to enhance performance and close the gap.
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-21-2012 01:50 AM
Stock all-season tires? Wait4BRZ_STI? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-03-2012 08:58 PM
Which stock JDM wheels do you prefer? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 40 02-08-2012 08:34 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 06:15 AM
Anybody considered using 16" wheels for the track? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 12-08-2011 10:55 AM
