Old 12-22-2013, 08:37 AM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Gas pedal dance brake thing.???
So I read on the forums about a gas pedal dance. Something like 5 slow presses, then off and on 5 presses again a and brake.
It was suppose to reset something.
As you can see, I can't remember the exact procedure, wanted to read the article again, but cannot find it. I did searches and read through a bunch I forums. Maybe spent 2 hours looking. Any help?
And no, not referring to the traction control pedal dance.
Thanks!
gdrider77 is offline   Reply With Quote
Old 12-22-2013, 09:03 AM   #2
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I've only heard of the traction pedal dance.
Dustin is offline   Reply With Quote
Old 12-22-2013, 09:05 AM   #3
gdrider77
gdrider77's Avatar
Yeah. This other thing had something to do with the throttle reset I think? Something to do with gas/throttle I believe.
That's the problem. Can't remember, dammit. I wish I ha subscribed to it. Now I can't find it.
Old 12-22-2013, 09:12 AM   #4
geeang
geeang's Avatar
Drives: Subaru BRZ
LOL @ throttle dance.
Drive-by-wire, what would the point of a throttle reset be?
I don't think there is such a thing, seeing as it would have no function.
geeang is offline   Reply With Quote
Old 12-22-2013, 09:15 AM   #5
z3ro
http://www.ft86club.com/forums/showt...ht=pedal+dance
took me like 2 minutes
z3ro is offline   Reply With Quote
Old 12-22-2013, 09:21 AM   #6
geeang
geeang's Avatar
Drives: Subaru BRZ
Originally Posted by z3ro View Post
You could have saved yourself 2 minutes by reading the OP's post closely.
Old 12-22-2013, 09:22 AM   #7
Dustin
Twin Screw You
Dustin's Avatar
Read in full
Old 12-22-2013, 09:22 AM   #8
gdrider77
gdrider77's Avatar
I think it has something to do with new tunes. Basically you flash a new tune, then there is an ecu learning time period. This speeds it up I think. That's why I wanted to re read the article.
Old 12-22-2013, 09:25 AM   #9
z3ro
Reading's for chumps, i'd much rather provide inaccurate information
Old 12-22-2013, 09:43 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
The throttle pedal voltage span isn't the same on all sensors. The ECU is programed to accommodate by learning the extremes and interpolating the span. After the ECU has been reprogrammed turn the ignition to on but leave the engine off, FULLY depress and release the throttle a few times, then start the car as per normal.
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 11:46 PM
Disappointed brake pedal feel, what am I doing wrong ZionsWrath Other Vehicles & General Automotive Discussions 12 11-15-2013 03:03 PM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 04:02 AM
Pedal Dance Imperative for Autocross/Track Black Tire Tracking / Autocross / HPDE / Drifting 5 04-22-2013 12:37 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 01:29 PM
