Old 12-24-2013, 03:52 AM   #1
uEih
Drives: CBS Subaru BRZ Limited
Trunk bumper protector
My car has a clear trunk protector to protect from scratching when loading things into the trunk, well I accidentally made a scratch and pulled a good chunk of the sticker, it is lifted and scratched a bit, doesn't look like I damaged the paint or anything but now there's a transparent white area that you usually get when you pull a sticker away or end up lifting part of a sticker and the adhesive is visible/white. My car is black so I can see it and it bothers me, idk how tough that sticker is but do you think if I heat the area up and push it down it'll clear up? By melting the adhesive, etc. It's a small problem but it bothers me and sticks out every time I look.
uEih is offline   Reply With Quote
Old 12-24-2013, 04:18 AM   #2
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I would use a product called goo gone. It's great for removing adhesive stains. I've used it when replacing my door guard on my Monte Carlo and it did not damage the paint at all.
cjsporl1996 is offline   Reply With Quote
Old 12-24-2013, 04:31 AM   #3
uEih
The thing is it's just a small spot and I wanna remelt the adhesive if possible, just wanna know if it's possible before I cause more damage. The best way to explain it is the sticker is lifted and stretched so it makes it look white, can I remelt that?
Old 12-24-2013, 04:38 AM   #4
cjsporl1996
Honestly From the way you are describing it I see no problem in attempting to heat the film up and re-apply it just watch the paint. From past experience clear protectors only like to go on once and after they are damaged it's better to get a new one because you will never be able to make it look perfect again. A Picture would probably give me a better opinion but this is based off past experience. Good luck
Old 12-24-2013, 04:45 AM   #5
uEih
I'll get a picture tomorrow when there's sunlight and post it. It kinda looks like it got to the paint but a closer look and I think it's only the protector. But yea I'll quote you and post a picture tomorrow
Old 12-24-2013, 10:45 AM   #6
gily25
Drives: Silica BRZ 6MT
Does it have a raised edge like a sticker or was it smooth? If it had a raised edge to begin with it probably wasn't installed right and should come right off like a sticker would. If you decide to replace it, go somewhere where they do clear bras, rather than having the dealer install it as an acccesory.
gily25 is offline   Reply With Quote
Old 12-24-2013, 01:37 PM   #7
uEih
Here's the picture, I just wanna be able to make transparent again, the dent in the applique sticker doesn't bother me as much as the white spot
Old 12-24-2013, 03:25 PM   #8
cjsporl1996
I'm pretty sure the bumper protector needs to be replaced. But try the heat gun out and let me know if that works
Old 12-24-2013, 03:39 PM   #9
uEih
Yea I thought so too but if I could salvage it I rather do that. I think the price of the appliqué sticker is too much and not really necessary for such a small issue, it did what it was suppose to hopefully and protected the paint. From the looks of it, it's only the appliqué that's damaged. But i'll try a heat gun when I get a chance.
Rear bumper protector denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 52 10-30-2013 02:13 PM
Any knowledge out there on paint protector spray film?? mostro New England 7 09-02-2013 10:04 PM
I Made a Driver's Side Floor Mat Protector, YAY SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 26 04-16-2013 05:44 PM
nav screen protector wallace03 Cosmetic Modification (Interior/Exterior/Lighting) 7 02-14-2013 01:56 AM
Front License plate/bumper protector Aloxi Cosmetic Modification (Interior/Exterior/Lighting) 3 11-20-2012 10:29 PM
