Drives: FRS
Body Kit Cause Issues?
I was planning on installing a replica TRD body kit. I know some parts of the kit install over factory painted panels and attach with clips and/or tape. My question is as follows: Is it possible for the body kit to move against the factory body panels while driving and rub paint off or otherwise damage the finish underneath? I just want to make sure the kit will not harm the finish of the car if installed properly.
Drives: JRSC'd Asphalt FR-S
It shouldn't but it doesn't mean it isn't possible, maybe if it was installed incorrectly. A member here had their oem mudflaps cause their paint to crack.
Just a dude
Drives: Scion FR-S 2013
Any and all kits can and will do this over time. Only way to prevent is to run some 3m film under the pressing edges. Even stock oem mudflaps cause some rub and wear marks.
#4 | |
Drives: Scion FR-S Coupe
Drives: Rocket Bunny'd GT86
Had my TRD spoiler on for about 4 months with 3m tape and not drilled into the trunk. Took it off later and I saw scratches that were notice-able when you look close, all body kits do this over time.
Drives: Asphalt FRS
Wouldn't a good polish remove those scratches though?
Drives: FRS
Hmmmm... This is interesting.
So I guess I will want to clear bra under the kit. I think I can handle that
Señor Member
Drives: 2013 Raven, Drifty things
yeah your best bet is to just do a 3m clear strip below the body kit. If you cut it JUST above the top edge of the front lip/side skirts/rear spats it won't be noticeable and when you take it off you can just peel off the clear. That's what I plan to do.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
#10 |
Drives: RX-7 / BRZ
It will have to be a foam tape like material (double sided 3m applique tape works.) Just apply clear vinyl tape to the backside won't do much. This is evident on any cheap truck fender flare you see a hundred times a day.
| Toyota Service Bulletin: Body Panel Fitting Issues | ahausheer | Issues | Warranty | Recalls / TSB | 99 | 03-07-2017 01:21 PM |
| Body Shop issues, need advice. | Inextirpable | CANADA | 14 | 08-15-2013 01:00 PM |
| How to make the body kit sit flush against the body? | JasonCDC | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-10-2013 05:07 PM |
| Parking Sensors - Dealer Accessory or Factory? Body Kit Issues? | sharkasport | AUSTRALIA | 14 | 12-18-2012 03:52 AM |
