Old 01-01-2014, 04:16 AM   #1
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Review: Supertek Industries intake tube
Placed an order on a new intake tube after my Perrin intake tube was getting cut up by the drive belt. I was looking into a clean design and @Supertek Industries had what I was looking for; wrinkle black with black couplings.
Straight out the box
Installation: It was a pretty easy install. I had a Perrin tube before so I had already taken off the sound tube. Took about 5 minutes to install. The package came with everything you need for installation.
Clearance from tube to drive belt
Old Perrin intake tube; notice the cut.
Driving impressions: Sounds great at WOT. Still has the same response as the Perrin intake tube gave me. The only small difference if any was maybe a better take off response. It feels slightly better than a rubber tube and construction is a A+
Shipping and service: quick and easy, very helpful and provided tracking number right away. Product arrived before given date which was pretty great after having a hard day at work, really got me happy to receiving this.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 01-01-2014, 11:06 AM   #2
xDanger_208x
xDanger_208x's Avatar
Drives:
Would you say this produces more intake noise than the silicon piece you had before?
xDanger_208x is offline   Reply With Quote
Old 01-01-2014, 11:56 AM   #3
s2d4
s2d4's Avatar
If it used rubber couplers and factory clamps, that would be as close to oem looking as possible.
Old 01-02-2014, 11:39 PM   #4
Supertek Industries
Supertek Industries's Avatar
Thanks for the review, we are glad you are satisfied. All other preorders are shipping shortly and look forward to more feedback!
Supertek Industries is offline   Reply With Quote
Old 01-04-2014, 07:23 AM   #5
FR-Sizzle
Drives: brz
Is the Perrin Intake Tube hitting the drive belt a big issue? I havent seen anyone report of that happening until your made this review. Could you of gotten a bad part perhaps?
I believe Evasive sells an intake tube too that is carbon fiber which is extremely nice. It is just a little more than the Perrin Intake Tube. I believe its like just around 200 bucks. 50 more dollars for a carbon fiber intake tube that has a similar design to Perrins with a smooth bend unlike the avo/zetas where it is just a 90 degree angle where the tube bends.
FR-Sizzle is offline   Reply With Quote
Old 01-13-2014, 05:46 PM   #6
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Figure I may as well add mine here instead of another thread.
Received mine today.
Outside powder coat was perfect, inside of the pipe was kind of weird.
There were a couple of dark mounds of something (I'm assuming from the powder coat?) that I scraped/filed down as well as some metal sticking out that I also filed down.
There where also pieces I took off the ends of the tube that were jagged/hanging off that I forgot to take pics of before filing down.
Inside the pipe is pretty rough, not sure if it's supposed to be like that or not.
Not a huge issue but I would expect to receive it without those defects considering the Perrin CAI is perfectly smooth on the inside.
Curious to know if others have the same issues.
These pics are after filing down the dark mounds but not the metal.
So after getting rid of that junk...
I also had no idea what the included little black plug thing was for so I shoved it on the sound tube thing.
Old 01-14-2014, 08:20 AM   #7
Supertek Industries
Hi,
Great pictures, looks like a nice setup!
In regards to the plug yes it is for the sound tube delete.
For the inside of the pipe, this is a cast aluminum unit so the texture inside will be similar to that of a OEM intake manifold or cylinder head.
As far as the metal sticking do not worry, we are having the production line go over EACH ONE today to ENSURE there will not be future issues and correcting.
Thanks for sharing!
Overall how do you like the sound and performance of the product?
Old 01-14-2014, 01:49 PM   #8
Andrew025
Andrew025's Avatar
Originally Posted by Supertek Industries View Post
Hi,
Thanks for sharing!
Probably just new mod placebo, but it feels like it pulls a bit better.
It definitely added a nice sound to the Perrin CAI. Also looks great with it as well.
Old 01-16-2014, 01:30 AM   #9
s2d4
s2d4's Avatar
yeah, I received mine too.
Decided to have a once over thanks to this thread.
It looks like they didn't take special care in not doing the inside so there is quite a lot of loose powder everywhere.
If I touch it, it flakes off.
Now that I've gone through and gotten rid of the all the loose powder, not entirely sure I want to put it on since I have no idea how well the powder is attached to the inside. Definitely don't want any of it to come off when the pipe heats up due to different rates of expansion between aluminium and the powder.
Looks like I'll need to take it to get it sand blasted to put my mind at ease..
Old 01-16-2014, 02:51 AM   #10
Hawk77FT
Drives: GTS 86
I like this! Which one would you guys say it gets colder air in the intake? i tend to believe that the silicone one, however the powder coating might make the whole difference to an aluminum tube.
Hawk77FT is offline   Reply With Quote
Old 01-16-2014, 05:19 AM   #11
jono_l
Drives: 86 GTS M/T 37J
As stated in the other thread in the vendors forum, mine is the same and I'm not comfortable putting it on the car until I have it sorted. Powder will flake off if I touch it, so this is effectively useless until I get it media blasted and/or have all the loose powder removed via other means.
Hi,
Since you guys are implementing a new production process to fix the issue, will us early adopters be able to get a replacement for tubes which are having such issues?
jono_l is offline   Reply With Quote
Old 01-16-2014, 10:31 PM   #12
Supertek Industries
We will honor an exchange for anyone that particpated in the original buy on the product and is not satisfied. We did quite a bit of testing over the past few days and found that although the current finish on the interior of the pipe does not pose any danger to the engine nor to performance we are working to correct it for the near future.. This may take a few weeks so please be patient with us.
Thanks everyone for your support and be assured we are working quickly to correct it!
Old 01-17-2014, 03:30 AM   #13
jono_l
Thanks for the update and reassurance that we will be looked after - appreciate that any new product has teething problems.
Please keep us posted on this
Old 01-17-2014, 10:37 AM   #14
ramiram1984
Drives: 2016 STi DGM
Prob didn't check clearance. With those things, it's always good to recheck after so many miles driven.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
NW Shop Review: BK Industries (Boise ID) DarrenDriven Northwest 1 03-16-2014 12:40 PM
SuperTek Industries 86 logo center caps SurfAndSand Wheels and Tires 4 10-11-2013 09:32 PM
Supertek Industries - New Parts Announcements Supertek Industries Announcements, Contests, Giveaways 6 09-15-2013 10:51 AM
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 08:18 AM
NW Shop Review: Portland Speed Industries (PSI) (Hillsboro OR) DarrenDriven Northwest 1 06-01-2012 02:29 PM
