Old 01-05-2014, 02:36 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Best way to clean your dry filter intake?
I have a Takeda Dry Air Filter Intake and just wondering the best way to clean it and how often. Thank you
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-05-2014, 02:43 PM   #2
ramiram1984
Drives: 2016 STi DGM
This is a tough one....
Stick it in the washing machine and then In the dryer.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 01-05-2014, 02:53 PM   #3
John92
Drives: White scion frs
It's called google or take 5 minutes out of your busy day to read the instructions on how to clean it.
John92 is offline   Reply With Quote
Old 01-05-2014, 03:25 PM   #4
humfrz
Without looking it up ...... I would guess that tapping it in a hard surface, dirty side down, then using a shop vac, sucking from the inlet side should clean it up.
In the old days, we used to blow it with an air hose (clean side out); which may have not been the best for future filtration....
How often? ..... well, every now and then ....
humfrz
Perrin CAI air filter clean Hawk77FT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 11-16-2015 12:56 PM
When to clean CAI filter Bg8780 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 10-25-2013 06:45 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 07:06 PM
