Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Steering wheel removal question.
I followed the DIY on here. Got the airbag removed. Removed the 17mm center nut. Steering wheel is still not coming off. Am I missing something? I'm pulling rather aggressively on the steering wheel to no avail.
#2 | |
Drives: 2013 Toyota 86/Scion FRS
Leave the nut threaded with enough space for the steering wheel to come out but not completely(prevents steering wheel from slapping you in the face), and pull forward left and then right to loosen the wheel. Slow but steady force to make sure you don't damage the splines. Last edited by iketiak; 01-11-2014 at 07:23 PM. |
Twin Screw You
Thanks. Now on to problem number 2. How do I fix this eff up.
![]() Not a great picture I know but the clock spring came unraveled. I've tried a number of different things so far and can't get the center on with the ribbon not being in the way.
Twin Screw You
Never mind. Just took a little trial and error to find the right rollers for the ribbon to come out of.
Drives: Toyota 86
I'm curious as to how you messed up your clock spring like that? I swapped out my steering wheel and it was fairly easy
Twin Screw You
Not sure. The steering wheel did not come off simply for me. Took a bit of force to come off the steering column. When it did finally come off, the cover for that ribbon came off with it. The rest as they say is history.
Drives: Grocery cart
That is why you need to leave the nut on the steering shaft so you don't end up pulling it out. You will need to replace the clock spring at this point.
Twin Screw You
Eh, we'll see.
According to the repair manual, it should turn 2.5 times in each direction when you have the clock spring set up correctly. Once you get the wires fixed and the housing attached you can look for a marking on the bottom of the unit.
#10 |
Twin Screw You
I did that.
#11 |
Drives: silver scion 10 series frs
anyone get an "ABS" and loss of traction light on? I put my sparco wheel on and then removed it to put the oem wheel back on, those 2 lights stay on. the airbag light goes away though...
2013 10 Series
2013 Raven FRS-sold follow me on instagram- WeaponsFree86 |
#12 | |
Stealth ***e
You can probably just get them reset at the dealer though for no charge. |
#13 |
Clockspring probably isn't centered. Try reinstalling the steering wheel taking special care to note position of clockspring is centered in relation to steering wheel center.
#14 |
I made sure the clock spring was centered. No difference
2013 10 Series
| Steering wheel accent removal | Gixxer86 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 11-27-2016 03:03 PM |
| scion frs steering wheel air bag and steering wheel | Jhon19lopez | Interior Parts (Incl. Lighting) | 7 | 01-04-2014 07:04 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-21-2013 12:45 AM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
| Steering wheel and air bag removal ZC6 (BRZ)/ ZN6 (86) | andrewFT86 | DIY (Do-It-Yourself) Guides | 0 | 07-08-2013 01:41 AM |
