Old 01-20-2014, 03:38 PM   #1
Moe23
Drives: 2014 Scion FRS MT
Knocking sound
This morning I started my FR-S, as the car was at cold start everything was fine, once the RPM dropped to idle there was a noticeable knocking sound from the engine while the car was still cold. Once the car had fully warmed up the knocking goes away.
Anyone else ever had that problem?
Moe23 is offline   Reply With Quote
Old 01-20-2014, 03:43 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
In cars with hypereutectic pistons (which this probably has - not sure), you will have noticeable "piston slap" until it warms up.
I have not noticed it. Did you have to get out of the car to hear it?
Old 01-20-2014, 03:52 PM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
My BRZ does the exact same thing, and it goes away when it's warmed up. I'm glad I'm not alone!
tobin is offline   Reply With Quote
Old 01-20-2014, 05:10 PM   #4
Moe23
No i can hear the noise from the inside of the car not the outside
Old 01-20-2014, 07:53 PM   #5
Mikem53
Drives: FR-S 6MT
Originally Posted by Moe23 View Post
This morning I started my FR-S, as the car was at cold start everything was fine, once the RPM dropped to idle there was a noticeable knocking sound from the engine while the car was still cold. Once the car had fully warmed up the had knocking went away.
I get it too.. Some say it's caused by the cat heating up. The engines knocks
and it feels like a backfire. Only a few stumbles and it smooths out. It's not piston slap..
Mikem53 is offline   Reply With Quote
Old 01-21-2014, 12:53 AM   #6
Moe23
The knocking lasting for about 20 minutes, is that normal?
Old 01-21-2014, 02:06 AM   #7
humfrz
Well, my FR-S doesn't do that ..... but it doesn't get real cold here.
I'd be a bit concerned if the "knocking" went on for 20 minutes.
Can you capture a video/audio and post it .. ??
....and, of course you have checked the oil level....
Old 01-21-2014, 02:53 AM   #8
Hakuzen
Drives: 2014 Scion FR-S
My car sounds rough on a complete cold start.. Almost sounds like its knocking for the first few seconds after ignition, but it never lasts more than a few seconds.
If that knocking noise persists for 20 minutes, I'd be concerned.
Hakuzen is offline   Reply With Quote
Old 01-21-2014, 09:00 AM   #9
Mikem53
Drives: FR-S 6MT
No..
Old 01-21-2014, 09:28 AM   #10
Muskokan
Drives: white Sport-tech
Was this thismorning? It's -40 with the wind chill up here so if your parked outside, my engine took over 20 m of driving to even move the temp quage.
My radio still hasn't turned on either
Hopefully my balls reappear soon
Edit: I see it was yesterday morning, still pretty cold. Go out thismorning and take a vid of start up and post it here.. Dress warm
Muskokan is offline   Reply With Quote
Old 01-21-2014, 01:20 PM   #11
Moe23
I will try to get a video of it knocking, and i got an oil change two days before it starting knocking, and oil level is fine
Old 01-21-2014, 03:19 PM   #12
BlackyRose
Drives: 2013 Raven FR-S
I live in Florida, and on cold starts I get 2-3 loud knocks withing the first 30 seconds and then everything is fine once I put her in reverse. The knocks are so bad that the car almost shakes a little bit.
No codes, no drop in performance, etc. Seems to be normal on our cars when they get cold
BlackyRose is offline   Reply With Quote
Old 01-21-2014, 08:20 PM   #13
Moe23
It doesn't knock during cold start, but right after the RPM drops to normal idle, and the knocking is constant for about 20 minutes, and the car does shake a bit with every knock
Old 01-21-2014, 08:41 PM   #14
humfrz
Well, if I had to guess, I'd guess your car has a coil/plug or the wire leading up to one of them acting up.....
Knocking sound from what sounds like rear suspension husker741 Issues | Warranty | Recalls / TSB 12 04-24-2017 06:26 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 12:34 PM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 04:20 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-08-2013 12:50 AM
