Old 01-29-2014, 07:35 PM   #1
swansons
Drives: 2013 Subaru BRZ Ltd WRB MT
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing
I had the Perrin Shifter Bushing for Rear Shift Rod (PSP-INR-006) installed shortly after I got my BRZ.
Does anyone know if the above shifter TSB replaces the Perrin bushing?
swansons is offline   Reply With Quote
Old 01-29-2014, 07:38 PM   #2
OrbitalEllipses
Drives: Attitude
Got the text of the TSB? That would help.
Old 01-29-2014, 08:36 PM   #3
HapaHaole
Drives: Grocery cart
NUMBER: 03-71-13
DATE: 07/01/13
APPLICABILITY:
2013MY BRZ
SUBJECT:
6MT Shifter Rattle and Improvement to
Reverse Pull Collar Operation
INTRODUCTION
This Bulletin announces availability of a revised 6MT shifter lever and an enhancement to the reverse pull collar assembly designed to improve the operation of the reverse selection mechanism. In addition, this new assembly will eliminate a rattle sound from the shifter which may occur primarily in 3rd gear between 3500 and 6000 rpm. While the rattle condition is most noticeable in the listed gear and rpm range, it may in rare cases be noticeable under other conditions.
COUNTERMEASURE IN PRODUCTION
The new shift lever was incorporated into production in December, 2012 starting with VIN: D2605967.
PART INFORMATION
SERVICE PROCEDURE / INFORMATION
Once the customer's concern has been confirmed to be associated with the shift lever, replace the lever assembly following the service procedure outlined in the applicable Service Manual.
WARRANTY / CLAIM INFORMATION
For vehicles within the Basic New Car Limited Warranty period, this repair may be claimed using the information shown.
HapaHaole is offline   Reply With Quote
Old 01-30-2014, 08:22 PM   #4
swansons
The best that I can tell from the TSB is that the shift iever is new. The bushing and boot are listed as R&R.
Old 02-02-2014, 03:27 PM   #5
conekiller
conekiller's Avatar
Drives: '15 WRBP Aozora Subaru BRZ
I am a technician for a Subaru dealer in Canada. I have performed this bulletin on my own brz as well as 2 other customer vehicles and can confirm you only replace the shift lever assembly and shifter bushing is left untouched.
Sent from my SGH-I717D
conekiller is offline   Reply With Quote
shifter bushing
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 03:39 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
SOLD: Perrin rear shifter bushing abutterman Transmission and Driveline 7 08-19-2013 02:57 PM
FS: Perrin Rear Shifter Bushing green_comet Australia Classifieds 2 11-07-2012 03:04 AM
