Old 01-30-2014, 04:46 PM   #1
xlid007
Drives: Scion FRS
Lowering Springs Installation Cost
I've been reading the DIY for the lowering springs and looks a bit difficult and I have to buy some tools in order to finish it. I was calling around different shops here in Miami and got quoted from $160 to $220. Anyone in SFL knows reputable shops that can do the install for lower or do these prices seems fair. I just don't want to spend so much time doing this or have a chance of messing something up. I feel comfortable installing mods but suspension is one thing I usually don't mess with.
xlid007 is offline   Reply With Quote
Old 01-30-2014, 04:54 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Those prices are not crazy.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-30-2014, 06:14 PM   #3
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Make sure they are a reputable shop you don't want to go somewhere that is cheap but they have no idea what they are doing... Do your research on the shop first
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-30-2014, 06:17 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Do it yourself. Assuming you have a 19mm, 17mm, 14mm, and 12mm sockets, a set of metric hex keys, a torque wrench, a spring compressor, and jack stands, you can do it in an afternoon.
supramkivtt2jz is offline   Reply With Quote
Old 01-30-2014, 06:18 PM   #5
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Street Rods and Classics in Boca Raton
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-30-2014, 07:06 PM   #6
Gunman
Drives: 2019 Mazda Miata RF
Check with Mad Mods in Ft. Lauderdale. I knew Bob Bauman's stuff from the early 90's, in his minitruckin days.
http://madmods.com/
Gunman is offline   Reply With Quote
Old 01-30-2014, 07:27 PM   #7
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
My local shop charged $250 including alignment
Old 01-30-2014, 07:40 PM   #8
vividracing
vividracing's Avatar
Those are some really good and reasonable rates.
vividracing is offline   Reply With Quote
Old 01-30-2014, 07:46 PM   #9
xlid007
Drives: Scion FRS
That's an awesome price. I looked at the diy again and I think I can get it done. I just have to buy a torque wrench and some tools. I'm probably going to spend close to 100 in tools but for sure I'll take my time and extra care.
I was thinking of taking it to Miami Performance Inc. If i can't make up my mind by when I get the springs, I'll do it myself.
Old 01-30-2014, 07:50 PM   #10
BlueDubbinTDI
I thought the same but since I don't have access to air driven tools I decided not to.
Old 01-30-2014, 11:08 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't use air tools to disassemble the shock/strut assemblies. In fact, you shouldn't do so as these OEM dampers have proven to fail when it's done more often than with other cars.
I do use air tools to remove bits from the car, but I've also swapped springs with hand tools at the track in less than two hours.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-31-2014, 12:37 AM   #12
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Got mine installed for $60 a corner.
I also needed rear LCA's installed since I was dropping lower than an inch. That was $35 extra per rear side.
Alignment was $60 after everything was done. $370 total.
This is probably a little pricier than what other people say, but I had went to 6 different shops and all the others' quotes ranged from $550-1,200 just for installation.
ericmpena is offline   Reply With Quote
Old 01-31-2014, 07:10 AM   #13
BlueDubbinTDI
I never looked over the DIY for the FR-S but on my Golf it was WAYYYY easier with air tools a buddy and I used. Guess next time around (I'll probably get coilovers eventually) I'll look into doing it myself. Where in FL are you located?
Old 01-31-2014, 07:13 AM   #14
BlueDubbinTDI
$1,200 is just laughable. Spring swaps are about an hour per corner max and since most shops charge $90-115/hr it really shouldn't be more than $400ish anywhere for this platform. My shop charges literally half what it needs to for everything it does and that why EVERYONE goes there around here.
TRD intake and exhaust pipe installation cost 2082FRS Engine, Exhaust, Transmission 12 01-25-2014 12:06 AM
Installation cost for a crank pulley? Readytoxplod Engine, Exhaust, Transmission 21 09-18-2013 06:54 PM
Cost of labor to installing lowering spring jshum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-09-2013 11:37 AM
WTS H&R Lowering Springs (Never used) g0ast Brakes, Suspension, Chassis 3 05-21-2013 12:34 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
