Drives: a Honda
What is the proper tire size for 18x10?
Might be picking up some 18x10 +44 RT's and do not want to run stretched tires. Is the bare minimum 265's? I know Jive Turkey and King Tut got those tires to fit (on 18x9.5) with minor modifications.
Drives: '24 GR86
205/45r18
Drives: '24 GR86
In all serious, 265 works well on a 10j wheel. 275 is essentially the same as a 265 on a 9.5
I've seen 275s used on 9.5s and it looks pretty solid
Drives: a Honda
Drives: 2003 Subaru Outback
Depending on the tire they may run wider or more narrow. on a 10 I would suggest 285 for optimal fit.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Depends a lot on the tire company. I've run a Nitto NT555 275/35 on the rears of my car and it works fine
Some say Nitto's run a bit narrow Nick C.
Drives: 2014 Asphalt Scion FR-S
I ran 255's on an 18x10 on my E90 for years. It definitely has a stretched look to it, and is probably as narrow as I would go on that size wheel
Drives: 2013 Raven FRS MT
I have seen people running 265s on the tire spec you mentioned. It seems that fitment seems to rely more on the suspension set up. There are brave souls out there that attempt this for us by taking a risk. I appreciate those people. I bet you can find someone on here to give you an opinion based on personal experience of the your desired set up. Keep us posted. Cheers.
Drives: Raven Scion FR-S
I run 265/35s on a 18x9.5 +38. Forgestar F14s Bridgestone potenza tires high performance all season tread width is 10.4" a 275 would be just fine with your setup but I do think they will rub and hit your springs for sure with that offset
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#10 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
When shopping for tires, look at the specs and locate the tread width of each. Some brands may have a 10" tread on a 275 tire, and some on 285.
| Tire size help | sharris721 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-19-2014 01:03 AM |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Appropriate tire size for 250-350 whp | Tiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 07-12-2013 03:40 PM |
| Help with Tire Size | Sivtec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-12-2013 01:40 AM |
| 225/35/18 Tire Size? | stoneman155 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-29-2013 09:09 PM |
