Old 02-01-2014, 08:38 PM   #1
swift996
swift996's Avatar
Need a little advice on coilover install
I was installing my intercooler and I took my strut tower off with the wheels off the ground. Both wheels fell down and out with the coilovers. They seem like a pain to get back and lined up to go back through the slots for the bolts. I tried taking a wheel off and using a jack.
Any suggestions to make this easier? Thanks in advance.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-01-2014, 08:45 PM   #2
wparsons
wparsons's Avatar
The less weight on the hub the easier it will be, and using a jack will make it easier still. The easiest way will be with a helper, one person to feed it from underneath and one person above to get the nuts started.
flickr
Old 02-01-2014, 10:25 PM   #3
Malt
Drives: 2015 WRX
Take the tire off, unbolt coilovers from the hub, bolt plates back to the strut tower, reattach the hub to the coilover, put the tire back on. It would take less time to just reinstall it like you normally would instead of messing around trying to save yourself from unbolting two bolts.
Malt is offline   Reply With Quote
Old 02-01-2014, 11:00 PM   #4
wparsons
wparsons's Avatar
^^ You'll want an alignment if you pull those bolts, just something else to keep in mind.
flickr
STX Coilover Advice ubersoph Tracking / Autocross / HPDE / Drifting 30 11-01-2013 08:34 PM
Need Coilover Advice for combined Street Comfort + Track Use distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-23-2013 05:15 PM
Spring/Coilover advice canuckbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-16-2013 08:09 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 08:37 AM
Coilover install cost? BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-14-2012 11:16 AM
