Old 02-04-2014, 06:35 PM   #1
Daned86
Drives: Asphalt FR-S MT
Extreme High Pitch Noise
Few days ago I noticed a very high pitch ringing noise, similar to this: http://www.freesound.org/people/klan.../sounds/28637/
The sound occurs fairly randomly but seems to appear mostly at low speeds and mostly occurs in 1-4 gear. It makes no difference if the AC or radio is on or off. The sound has not occurred while my engine is idling. It's fairly loud and very hard to pinpoint where the sound is originating from.
The only other type of example I've found of the sound is from an old 370z thread and people were fixing the problem by having their ECU's swapped out.
If anyone has any ideas or suggestions that'd be helpful, I plan on taking it in to the dealership Thursday but the randomness of the issue has me worried about them finding a solution in a short test drive.
Edit**
Car was purchased new in May 2013 and currently has just over 6900 miles on it, 6 MT, completely stock.
Daned86 is offline   Reply With Quote
Old 02-04-2014, 06:52 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Let us know as this is my car almost to the tee. I have some rattling type noises from my rear seat I decided to just put up with until I take it for my second oil change (10000 miles). I hate it when the dealer has my car
Old 02-04-2014, 09:26 PM   #3
humfrz
Sorry, I can't hear anything. Maybe my computer is not playing it or my ears are deaf to that tone .. ??
Just guessing ..... could it be a differential whine .. ??
Old 02-05-2014, 12:33 PM   #4
Daned86
It is incredibly high pitched, it's definitely something electronic and I believe I've found the culprit.
The sound appears when I use my blinkers, particularly my left blinker. Still doesn't happen everytime but when I turn them on I can hear it. Hoping it's just a bad ground or bad relay.
Old 02-05-2014, 12:44 PM   #5
humfrz
or, maybe it's the flasher thingie .....
Bc racing extreme drop clunking noise. Low&Slow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 12-17-2013 01:13 AM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
Engine high pitch sound Munki Engine, Exhaust, Transmission 8 10-15-2013 03:11 AM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 02:12 AM
