Old 02-12-2014, 02:02 PM   #1
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Exclamation Really odd engine noise
It sounds like metal on metal maybe, or something of the sorts. I do know its not the engine itself, would it just be a really odd twist on the DI pump strangeness I wonder?
Link to video:
https://www.dropbox.com/s/v1sxudsmum...212_135335.mp4
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 02-12-2014, 02:11 PM   #2
Deadspool
Much title. Wow.
Deadspool's Avatar
amplifying information, the noise goes away anything after 1k rpm, does not make this noise at cruise.
Old 02-12-2014, 02:22 PM   #3
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Can't listen because i'm in class, but how do you know it's not the engine? (especially given it's rpm dependent)
Thorpedo is offline   Reply With Quote
Old 02-12-2014, 02:26 PM   #4
Deadspool
Much title. Wow.
Deadspool's Avatar
It continues after shutting it down and becomes louder, makes whale noises
NRUUUUWOOOWUWUWOWOWOowoOWUWOOooooooo
Old 02-12-2014, 02:29 PM   #5
Thorpedo
The SquadWhisperer
Hahaha my bad. Apparently I should have watched the video as I didn't see that one coming.
Old 02-12-2014, 02:31 PM   #6
Deadspool
Much title. Wow.
Deadspool's Avatar
lol, its all good. There has been no ill effect for driveability yet. But I imagine I will be in for a bad day if I ignore this.
Old 02-12-2014, 02:32 PM   #7
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Bearing?
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 02-12-2014, 02:51 PM   #8
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
If it does it when cold, you could try taking the serpentine belt off and starting it for a few seconds, (no more than 40 for safety) that would isolate it to any pulley bearings/accessories or rule out any of them if it still does it. Plus you could spin the pulleys by hand and check for wobble, or rough or stiff rotation.
Old 02-12-2014, 02:56 PM   #9
Deadspool
Much title. Wow.
Deadspool's Avatar
My apologies, I had forgotten to mention that it make the noise when warm. I will pull the serpent belt off to eliminate pullies for certain.
However the noise persists after the engine has been shut down for a few moments, as if relieving pressure.
Old 02-12-2014, 03:08 PM   #10
FrsDuke
Fanboy
FrsDuke's Avatar
Sounds like turbo bearing to me.
TL;DR:
-Duke
Old 02-12-2014, 03:13 PM   #11
Target70
Target70's Avatar
I saw that on the video, I just thought it was something spinning down. That does sound like metal on metal, and if it keeps doing it after the crank is stopped, and only does it when it's warm, maybe it is the cooling fan(s).
Other than that, I have never heard a turbo bearing go out, but I would have to agree with FrsDuke, something that keeps spinning for a few seconds after the engine cuts off and is metal on metal = turbo.
Old 02-12-2014, 03:23 PM   #12
Deadspool
Much title. Wow.
Deadspool's Avatar
I will check shaft play right now.
Old 02-12-2014, 03:30 PM   #13
wheelhaus
wheelhaus's Avatar
Subscribed, this is a strange one...
wheelhaus is offline   Reply With Quote
Old 02-12-2014, 03:50 PM   #14
Deadspool
Much title. Wow.
Deadspool's Avatar
Turbo feels good. no evidence of it touching the compressor housing.
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 01:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 07:39 AM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 11:30 AM
Noise coming from the engine. Zoomryder Scion FR-S / Toyota 86 GT86 General Forum 11 01-26-2013 11:07 AM
Engine noise... advice? hyperpunx Issues | Warranty | Recalls / TSB 8 09-28-2012 01:57 PM
