Old 02-14-2014, 07:36 PM   #1
nelsmar
Arrow Full engine teardown picture thread. Taking requests. (PICTURE HEAVY!)
As many if you know I had suffered engine failure many months ago. I have finally managed to take the time to do a full engine tear down. Every last bolt has been removed, tagged, and bagged. I figured as crawford was the only one to do this previously and they were directly told not to post any further due to not paying for sponsor status I would forward the offer to take any photos that anyone may want to see of any components before I re-assemble over the coming weeks!
I will be taking a few standard pictures of the damaged components in my engine but if there is anything that anyone is just curious about I can attempt to arrange to take quality photos of them. I shoot professionally and will be setting up a small setup for snapping some pictures of things. I'll try to get as many requests as possible but I am also fairly busy over the coming weeks.
I will attempt to take pictures over the weekend / early next week. So please post any requests you may want in this thread!
P.S. full build thread coming soon!
My flickr - Canibeat
Local magazine scout
Old 02-14-2014, 07:44 PM   #2
nelsmar
Okay I did a quick lighting setup in the kitchen... Here are a few photos of some failed parts.
Piston #3: seized rings and many pits
This is where the rings are compressed and seized
Misc abrasions signs of friction
Piston #4: Lots of pits, note the edges being discolored
Piston #2: Failed cylinder. Multiple impact marks. Piston touched head & valve. Exhaust valves are bent in this cylinder. Rod broke below wrist pin and put 2 large holes and one very small hole in the block. Rings are seized and face seems to be slightly warped. Piston contains many cracks.
Note that the piston seems slightly warped from this angle
Piston #2 Bearings
Misc DI's (Sorry they got dirty POST removal!)
Spark plugs: In order from cylinder 1 on the left to cylinder 4 on the right. I may have mixed up 3 & 4 but they look nearly identical. It is quite obvious which cylinder failed in this photo...
Intake Manifold & CPC Solenoid
Note the injector clamps i installed on the vacuum hoses that came loose during forced induction. These are not factory.
Old 02-14-2014, 07:44 PM   #3
nelsmar
Reserved #2.
Old 02-14-2014, 08:02 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
How do the piston tops look or was there too much shrapnel in the chambers to tell? From your review thread it sounds like you would have been detting for a while so i would expect the piston top to be pitted...
Old 02-14-2014, 08:06 PM   #5
nelsmar
Yes quite a few pits, especially around the piston edging. My engine let go at a low revolution luckily so the shrapnel was minimal. All four pistons are "mostly" in tact. One piston did slap a cylinder head and bent a valve. However it was minor. I actually just noticed the valve was bent as I was posting this.
Two pistons has seized rings, one piston had damage from hitting a head, and all four had pits. Although considering the conditions it was actually a lot better than I expected! I'll have photos of the pistons likely tonight. I just have to finish up a few things at work right now and then go pickup some cloth or something to shoot against.
Old 02-14-2014, 08:21 PM   #6
Captain Insano
pics of heads? better yet, while you have them off could somebody in the community maybe help you have them flow tested (unless you already have contacts for that)?
Cams info? Ton's of speculation on those here on the forum without much info.
I know you are busy and on a budget so if you can't do that stuff no worries. Just thought I would throw it out there.
Old 02-14-2014, 08:21 PM   #7
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
I'm interested in seeing your build. Which pistons and rods are you going with? Are you doing anything to the block, heads, valve-train, cams, intake & manifolds, etc?
Just for reference here is a thread I found regarding a FA20 build: http://www.ft86club.com/forums/showthread.php?t=28820
Drift&Drag is offline   Reply With Quote
Old 02-14-2014, 09:06 PM   #8
Deathreaper
Drives: 2013 Scion FRS
Thank you for this - much appreciated by the community. How do the DI seals look on your car (if anything is left of them)? I assume when the car was functional that you shifting quite a bit post 4-5K rpm?
Deathreaper is offline   Reply With Quote
Old 02-14-2014, 10:07 PM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
X2 on the heads...
Also intake manifold from several angles...do you also happen to have the crankshaft out?
A pic of the DI seals wouldn't hurt either...
Old 02-14-2014, 10:14 PM   #10
nelsmar
What's it cost to get this done these days? I would have to ask some friends as I don't have friends locally to do this. I'm def on a budget ATM as the build is becoming costly but I'm open to the idea.
I spent quite an amount if time over 4k. Seals looked good considering I did have DI pop pre-tune/boost which went away after flashing. I will get detailed pictures of all four for you. One DI has minor damage on what looks like a washer at the base before the seal. May have been from removal as we really had to tug to remove the DI from the cylinder with the failure in it.
X2 on the heads...
A friend has the crank shaft I gave it to him. I will ask him to return it for photo this weekend for you. And every boot has been removed from he engine. Exception two Allen plugs in the block it's self. I even removed the cover from unused the bell housing in the back of the block.
I asked a friend to get me photos from the evening during tear down. I'll post some of those up when I get then. If I get some time I'll start with manifold, pistons, DI system tonight.
Old 02-14-2014, 10:23 PM   #11
nelsmar
Lots of parts to list. Custom speced CP @ 11.5:1 CR with coated tops and upgraded wrist pins. Modified Carrillo 1200hp h rods... Upgraded valve springs likely upgraded valves now that some are bent and I'll be treating a number of oem components. I have spent months sourcing parts and doing research it'd been a pain! But I am getting closer. I still need to buy a few parts. I won't be shooting for the sky as I don't want to do a custom transmission and diff setup ATM as it's quite costly. But it should put down nice numbers. Basically whatever my turbo maxes out at. Or the fuel system whichever comes first.
Old 02-14-2014, 10:38 PM   #12
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Sounds bad ass! So you're getting rid of the supercharger and going with a turbo setup ?
Old 02-14-2014, 10:43 PM   #13
nelsmar
Figure ill give it a try. If I don't like it I'll likely go back to a vortech race unit and just raise up the rev limit so I still get rational MPG.
I just want to be able to give a fair comparison to both on this car. I honestly absolutely loved my supercharger and I swear by the setup I had. But for the money im investing into a bottom end I feel a turbo will better suite now that I can self tune. I am more biased towards using the supercharger though I feel it fits this car better.
Old 02-14-2014, 11:04 PM   #14
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
You won't regret it bro! What are your HP/TQ goals?
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 CSG Mike Issues | Warranty | Recalls / TSB 909 09-15-2016 11:31 AM
Forza 5 Picture Thread - Post up your shots! GuerillaRacing Other Vehicles & General Automotive Discussions 32 01-15-2015 05:48 PM
Post a picture of your 86 DRIFTING! tiz22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 90 03-17-2014 02:35 PM
Post a picture response to the last one posted JayNutter Off-Topic Lounge [WARNING: NO POLITICS] 146 02-27-2013 01:49 AM
POST A FUNNY PICTURE OF THE BIG DAY MEETING THE 86!!!! FT-86GOD AUSTRALIA 111 06-26-2012 08:35 AM
