Old 02-18-2014, 01:10 PM   #1
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Springs, Sway bars, Strut bar, what's next???
What is the next modif after this?
I want a go kart
Do you think a rear strut bar is a good idea? But I don't want to have a bar in the trunk who make storage interference... Sometime i fit my mountain bike in the trunk...
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-18-2014, 01:18 PM   #2
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Adjustable shocks, bushings, underbody bracing, wheels and tires.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-18-2014, 01:22 PM   #3
Mikepage
Mikepage's Avatar
Already rack and pinion bushing it's a good start.
Am not ready for bushings yet... Too expensive for a minimal difference, correct me if am wrong.
o= FR-S =o
Old 02-18-2014, 01:25 PM   #4
wparsons
wparsons's Avatar
You'll get more difference replacing bushings than you will from strut tower bars (especially the rear since that doesn't effect the suspension geometry).
Beyond "a go kart", what are you trying to achieve? What tires are you running? Do you want street grip or track grip? What alignment specs are you running? What springs and sways?
flickr
Old 02-18-2014, 01:26 PM   #5
Guillaume
Guillaume's Avatar
Drives: Exige S 240
More camber, proper alignment settings.
http://ft86speedfactory.com/suspensi...amber-kits-87/
Old 02-18-2014, 01:29 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you are wrong
engine, transmission, diff, and rear crossmember bushings will absolutely transform your car.
Old 02-18-2014, 01:31 PM   #7
Mikepage
Mikepage's Avatar
Mach V springs
Whiteline rack and pinion bushing
Whiteline rear 16mm sway bar with link and braces... Middle position
Whiteline front strut bar
Hotchkis front 25.4 mm sway bar soft position.
The alignment is near to 0.
I don't have any camber adjustment stuff yet.
I will buy a new set of tires this summer, I do not kill the OEM tires yet.
I want street tires more then track tires.
o= FR-S =o
Old 02-18-2014, 01:39 PM   #8
Mikepage
Mikepage's Avatar
Originally Posted by 7thgear View Post
you are wrong
You have it already?
I think this topic will come interesting...
o= FR-S =o
Old 02-18-2014, 01:42 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not on this car but i've had on other cars, most notiably the impreza.
if you're looking for that go-kart feel, then those 4 areas are a must.
esp the rear crossmember mount, that has a lot of play. You can start by getting the whiteline inserts for that and work your way up.
i'm holding off because i want to play in autocross c-stock class, but once i'm ready for STX those will be my first mods.
Old 02-18-2014, 01:45 PM   #10
Mikepage
Mikepage's Avatar
Ok then I will check to place an order for the rear cross member bushing soon. It's just more difficult from my country to get a good deal because it's always a big shipping cost unfortunately...
o= FR-S =o
Old 02-18-2014, 01:45 PM   #11
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I will buy a new set of tires this summer, I do not yet kill the OEM tires.
I recently did the "OEM Camber Bolt" mod (see there : http://www.ft86club.com/forums/showthread.php?t=22201 ), giving more front camber while remaining fairly conservative (-0.8°). It transforms the car's cornering.
You can get more extreme values with some eccentric bolts and/or top mounts.
Old 02-18-2014, 01:46 PM   #12
Racecomp Engineering
Rear strut mount is a waste.
A better alignment, bushings, and shocks are your next steps.
- Andy
Old 02-18-2014, 01:51 PM   #13
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
You're in Canada though...where specifically are you?
Old 02-18-2014, 01:57 PM   #14
Mikepage
Mikepage's Avatar
Québec
o= FR-S =o
FR-S TRD Lowering Springs and Sway Bars releasing soon gvan1998 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 405 12-01-2015 07:48 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-24-2013 12:42 AM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 10:41 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
