Old 02-19-2014, 08:59 PM   #1
mongiamc10
Drives: 2014 FR-S
weird noise from clutch pedal area...
it usually happens when i am shifting from 3rd to 4th, 4th to 5th, at higher RPMs usually 5-5.5k +. I feel the noise in my foot when i push the clutch in and disengage going into the next gear.
Is this normal? is it possibly just the noise under load or high RPM?
or could this be an issue...?
once again the noise is not from the transmission or the gear box, i feel it in the clutch pedal area more than anything.
any help would be great. thanks guys.
-Adrian
mongiamc10 is offline   Reply With Quote
Old 08-06-2014, 09:03 PM   #2
yaguphire
Drives: white-out FR-S
-Adrian
Clutch premature failure?
yaguphire is offline   Reply With Quote
Old 08-06-2014, 09:36 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
is it a wooshing sound or more of a loud clicking sound? I have wooshing sounds at high rpm shifting especially when I shift fast.
Old 08-07-2014, 02:03 AM   #4
Error
Error's Avatar
Drives: FRS
I've actually posted about something similar to this maybe a week ago, I can feel the engine rpm through the clutch pedal as I press it in.
http://www.ft86club.com/forums/showthread.php?t=71114
Error is offline   Reply With Quote
Old 08-07-2014, 11:04 AM   #5
Imrac
Drives: 13 SWP BRZ Prem
Drive by wire has a small delay between when you release the gas pedal and when the throttle actually gets reduced. Maybe try releasing the gas pedal a couple tenths of a second before pressing in the clutch. I noticed the RPMs will blip if I release the gas at the same time I press the clutch.
Maybe that is what you are experiencing?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 08-08-2014, 07:04 PM   #6
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I get a noise from my clutch that sounds like a car honking. It only happens when the car is cold, and usually from first to second. but yeah, i always think a car is honking at me. passengers have commented too.
2much is offline   Reply With Quote
Weird HPFP noise Hakuzen Issues | Warranty | Recalls / TSB 19 01-29-2014 05:53 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-02-2013 12:42 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 06:35 PM
weird noise when I go up on my driveway on an angle..HELP!!! abling2 Issues | Warranty | Recalls / TSB 11 07-31-2013 10:59 AM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 02:46 AM
