Old 02-25-2014, 01:56 PM   #1
JerryMichaels7
Drives: Whiteout FRS
Help about to pull the trigger....
on a set of wheels! RPF1'S 17X9 now the big question for me that i can't decide is 45mm or 35mm offset. I know the 35 will clear (a) BBK, but other than that is there any reason to go with the 35? I ask because I can get everything shipped from tirerack and mounted with the 45, so for ease thats awsome. I have coilovers and adujustable sway bar endlinks if that matters as i read that on stock suspension at full lock 45 slightly rubs.
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-25-2014, 02:21 PM   #2
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
35mm because.."That Ass"
TONYpepperon1 is offline   Reply With Quote
Old 02-25-2014, 03:10 PM   #3
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
call tirerack they will sell you 35 mm
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 02-25-2014, 04:12 PM   #4
JerryMichaels7
say what!!! that would be awsome then...will do that
Old 02-25-2014, 04:19 PM   #5
JerryMichaels7
called and unless I just talked to the wrong person they don't have that offset, from my understanding everyone that has that offset for sell they are custom sizing.
Old 02-25-2014, 04:43 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
+35 clear's BBK's easier from what I understand - could be important in the long run for you (depending). Could be wrong. just going by memory
Corrected See CSG mikes post for more details, my bad
Old 02-25-2014, 04:58 PM   #7
Nhil
Drives: 2013 Scion FRS
+45 offset will not clear a bbk, +35 only just clears most of them. +35 is a custom offset in a 17x9 and will need to be purchased through either a group buy or a vendor who has them in stock. There are plenty floating around in the vendor classifieds.
Nhil is offline   Reply With Quote
Old 02-25-2014, 05:05 PM   #8
2pt5RS
Berz
I've been dealing with @OAKOS Automotive all day...they've been fantastic. hopefully I can make my mind up and get something from them!
2pt5RS is offline   Reply With Quote
Old 02-25-2014, 05:41 PM   #9
+45 will clear a BBK with a spacer, but you'll need extended studs.
+35 will clear all BBKs, but it's close.
+45 is aerodynamically superior, but you'll need to keep an eye on your inner edge of the tire; wider tires might rub your suspension, if you're on stock springs/dampers.
Old 02-25-2014, 05:47 PM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
This guy, this guy knows everything.
I will correct my post
Old 02-25-2014, 05:50 PM   #11
I wish I did... wait I probably don't... but I want to know more.
Old 02-25-2014, 06:20 PM   #12
JerryMichaels7
LOL so with coilovers there shouldn't be any rubbing issues with the +45? if so i think i am going with those and 255 zII's
Old 02-25-2014, 07:12 PM   #13
CSG David
CSG David's Avatar
It'll be very close...
About to pull the trigger on the Pioneer 8500BHS ravenblackfrs Electronics | Audio | NAV | Infotainment 4 10-11-2013 06:12 PM
How many of us are waiting to pull the trigger? Phantobe Scion FR-S / Toyota 86 GT86 General Forum 13 08-26-2013 05:54 PM
About to pull the trigger on Perrin.... FRSFirestorm Engine, Exhaust, Transmission 143 05-04-2013 02:25 AM
To pull the trigger or to wait? that_one_guy Scion FR-S / Toyota 86 GT86 General Forum 17 10-24-2012 05:17 PM
2007 STi... should I pull the trigger? RRnold Other Vehicles & General Automotive Discussions 25 02-23-2010 10:37 PM
