Third brake light causing rattle
Just installed a subwoofer and the rear windshield significantly rattles now during some notes of bass. I started to track down what exactly was causing it and found it was due to the third brake light rattling against the window. Does anyone know how to lower the third brake light, even the slightest bit? I pressed down on it with my hand and the rattle immediately disappeared.
Crickets...
Drives: FR-S 10 Series
I have the same issue.
Smile on every turn.
How about double sided foam tape? It'll stay put and cushion at the same time!
Drives: Subaru BRZ Limited
Mine had this issue after getting a sub. I tried to wedge some rubber stoppers between the 3rd brake light and back windshield. It fixed the problem, but then one day I saw my 3rd brake light had warped under the pressure from the rubber stoppers. I removed the rubber stoppers and also found out that they had partially melted to the rear windshield...
![]() I ended up pressing the 3rd brake light enclosure back together and then just dealing with the rattle. I've been wanting to get like Dynamat or something similar, but I just haven't had the time.
#6 | |
LOL PWR
Drives: Whiteout FR-S; Scion tC
It's not a midlife crisis if you never grow up. |
#7 | |
LOL PWR
Home Depot... $3
Not that I am a cheap bastard but I like to save money when I can ![]() *edit* My wife wants me to clarify that I am indeed a cheap bastard
#9 | |
#10 |
Turn down the one-note bass?
#11 |
Drives: 2014 DGM BRZ MT
Don't fix it!
As soon as you fix it, you'll hear the next thing that's rattling which will be much harder to fix or ignore... |
#12 |
LOL PWR
Had to unbolt and lower the amp to get to the bolts holding the third brake light in. Pulled light assembly off of rear deck, installed insulation on the light (not the rear window), trimmed with a fresh razor, and reinstalled everything. Took a little time but the results were worth it.
#13 | |
#14 |
LOL PWR
| Rattle from break light behind rear windshield! | Danny | Issues | Warranty | Recalls / TSB | 2 | 07-01-2014 12:26 AM |
| Major bump in the road causing TPMS light? | Chauntalei | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-20-2013 01:56 PM |
| For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 08:26 PM |
| Subwoofer 3rd Brake Light Rattle | mmieszanek | Electronics | Audio | NAV | Infotainment | 5 | 05-01-2013 01:21 PM |
| Stereo + Rear Brake Rattle | ckcrown84 | Electronics | Audio | NAV | Infotainment | 13 | 04-30-2013 09:29 AM |
