| CANADA Canada |
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Got a dent underneath..
Here's the story..
I was chaning to summer tire yesterday and I jacked up my car on wrong spot.. and got a dent underneath (right behind the passenger side front wheel) Fitment is slightly uneven. is any local shop could fix this problem? |
Drives: 2013 Scion FRS
![]() 2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
Dances with Cones
Drives: 2013 Scion FR-S Raven
I would doubt that's structural. It has probably just damaged the fender.
I'd check www.car-part.com and see if you can find a matching colour fender with no damage and swap it. Or check with members on here. Aftermarket paint is never as good as OE. The other option would be to see if a paintless dent shop could do the work. Try to avoid paint work though as it will never be the same.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
Just too upset about how stupid I was.
Damn. |
Drives: 4 wheels
Ugh. That's not a good one.. even the door gaps moved...
Dances with Cones
Because the fender is bent. Not because the door moved or the rocker is bent.
Drives: 2015 Trailhawk
Damn... I am so paranoid about this happening whenever I jack my car up or its on a lift.
On another note... summer tires already? The temps are still below zero at night around the GTA. In fact, this morning, the roads coming off the escarpment had ice all over them from the melt/freeze overnight. Good luck man! |
Adjusting fender was just about $60 bucks, so I did. Rocker Pannel I don't mind because I'll put TRD side skirt, as well as Front lip..
this is really sad though.. watch out when you are jacking up the car. |
Drives: MiniVan
Next time PM me, I work with a Paintless Dent Removal guy. We can help you out.
| Article: Toyota 86 viewed from underneath | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 01-20-2014 04:03 AM |
| Dent :( Will paintless dent removal be able to get this out? | Greg_Di | CANADA | 22 | 09-01-2013 12:22 AM |
| What is this underneath the car? | FRSHunter | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-06-2013 11:32 AM |
| Whats underneath your Scion FRS?? *VIDEO* | Push | Engine, Exhaust, Transmission | 18 | 09-17-2012 11:53 AM |
