Drives: 2022 BRZ Limited
I just wanted to see if there is a way to achieve -2.0 front and similar rear camber with stock suspension. I've searched and many people claim that the camber bolts help that as well as the camber plates and/or aftermarket control arms but I would rather not to use anything besides the camber bolts.
What kind of camber bolts did you end up using with the stock setup and how much of camber you gained? I think the best route would be coilover and lower ride height to do that but I just want to be able to use my R compound tires (235/40/17 Nitto Nt01s with Enkei RPF1 17x9 +35mm wheels) with stock suspension for now to and upgrade it gradually. Thanks in advance
Drives: '13 DGM BRZ Limited
Maybe lowering springs and camber bolts? Then save up for coilovers if that's what you want.
Drives: Some rust bucket
Impossible to gain -2 at the front with just bolts. Lowering springs won't work either because the front doesn't gain camber under compression. Max camber I've seen with just bolts is -1.5. You could slot the strut, which would give you more camber.
What kind of camber bolts can I use on this car?
Any bolt is required for the rears? Thanks
It seems that most people get about -1.3 with just one set of camber bolts. Not sure how far a second set of bolts will take you, but I doubt it'll get you to -2.0.
Edmunds got -2.0 max on stock suspension using HVT camber plates, so that might be the route to go if that's your target. http://www.edmunds.com/scion/fr-s/20...er-plates.html
2022 BRZ Build 2013 FR-S Build |
Drives: WRB Limited
I've been searching this topic myself for a few days now and came across this thread:
http://www.ft86club.com/forums/showthread.php?t=44660 Looks like running camber bolts on both the top and bottom can get you the camber you're looking for.
So...at last we meet for the first time for the last time...
#7 | |
No bolts for the rear. You'll need adjustable lower control arm or upper control arm bushings to get rear camber. You could also lower the ride height to gain negative at the rear. |
#8 | |
Señor Member
Also I am 90% sure the front struts do gain camber as they compress or are lowered.
1974 TA22 Celica
2013 86 GT |
#9 | |
Increasing positive caster will also increase negative camber when the wheel is turned. There's no factory caster adjustment, but I thought it's worth mentioning. |
#10 | |
Thanks again
#11 | |
#12 |
Drives: FR-S Whiteout
I can confirm for certain that -2.0 front camber is achievable with doubled up SPC camber bolts. Although every car will be different, also might be different side to side. It's probably more like -1.9* camber (+- .2*) You'll likely get more if you just slotted your mounting holes tho... but I have no experience with slotting the holes.
And yes you do gain a tiny bit of camber lowering the front end. I can confirm that certainly as well. |
#13 |
#14 |
Drives: '13 BRZ Ltd
I bet you could get -2 up front (and possibly more) by doubling up on the OEM available crash bolt. Someone else with a more structural background would have to comment on how advisable that is.
But I'd feel better with the OEM crash bolt vs. aftermarket - the threaded portion is still the same dia/pitch and the torque/clamping force is still the same as stock. The aftermarket ones (at least the SPC) are narrower and have a lower torque spec. |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| Cheapest way to get more camber on stock suspension | Snake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-11-2014 09:45 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
| Front stock struts/bolts max camber Q.. | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-15-2013 05:45 PM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 09:51 PM |
