Turbo coolant lines GTX2867. Can I use the throttle body coolant lines?
Has anyone had any issues with the turbo not getting enough coolant on their GTX2867?
Mine was leaking oil, and after sending it off, it was determined that none, or not enough coolant got to the turbo and damaged it. Everything was installed as per the instructions, including the oil restrictor. Coolant lines were installed and run as per the instructions. It's baffling me how the turbo could not be getting enough coolant. Could an air bubble get trapped and block the coolant line? I read about someone using the coolant lines that go to the throttle body. Is this OK to do? If it is, I'm tempted to switch to the throttle body coolant lines just to eliminate the possibility that the other lines aren't working properly. Thanks for any help, Mike |
I Love custom Turbo kits
Drives: Limited BRZ
Yes, use the throttle body lines. I use them in my kit and its what the AVO kit instructs to use.
in orbe terrum non visi
Drives: violent
I dont know what lines you are using but fbm instructions are to use the throttle body coolant lines. They supply fitting that T into the TB lines. I personally didnt use them and essentially put the turbo in the coolant system where my TB used to be.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#4 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: Sterling BRZ Ltd
An air bubble could have been trapped but usually that would work itself out after a little bit. Certainly not long enough to do damage I would think. On my setup I run the coolant lines from the TB supply lines. I didn't use Tees though just cut the TB out of the circuit all together.
Drives: 13 swp limited
Will there be any issues not running coolant to tb ?
I've done it on numerous cars and never had a problem. Maybe if you live in a super cold climate. I also don't drive my car in the winter.
Drives: FR-S 10 #103 AT
The liquid is not there to cool the TB. It's bringing engine heat to it for cold weather driving. Kind of like how old cars had a duct that funneled hot air up to the intake during the winter.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
On my way to pick up my car.
The company was nice enough to repair the turbo under warranty. The report stated lack of, or no coolant flow. The shop eliminated the coolant lines to the throttle body and ran those coolant lines directly to the turbo and reported improved coolant flow to the turbo. I'm hoping this solves the issues that caused the original turbo to spring an oil leak! |
| Coolant, Anyone tried this?? | stevo_12v | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 04-27-2016 05:50 PM |
| low coolant | BRZPDX | Northwest | 17 | 06-06-2015 02:42 PM |
| is my coolant low? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-20-2013 12:43 AM |
| Where did my coolant go? | ZionsWrath | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-02-2013 12:46 PM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 01:03 PM |
